Results 14 to 26 of 54
Thread: oversized. Now what?
07-10-2008, 11:31 AM #14
- Jun 2003
- 115
07-10-2008, 11:40 AM #15
If they are all the same size, but different lengths, you are not getting the same air flow from each.
Even the same lengths don't have the same air flow most of the time.
07-10-2008, 11:53 AM #16
- Jun 2003
- 115
07-10-2008, 11:59 AM #17
The 1050 would be enough air for a 3 ton A/C.
But doubtfull your getting that total through those 10 supplies.
07-10-2008, 12:01 PM #18
- Jun 2003
- 115
also, as an FYI, when I do a set back during the day, basically have the system off all day until get home, I can bring the temp from 81 or 82 inside to 75 inside in like an hour and a half to two hours. However, the system usually has to shut itself off once or twice prior to reaching the set point on the t-stat. It can usually run close to 45 minutes to an hour continuously prior to having to shut itself down for 5 or 10 minutes, then turns on again to get down to the set point.
Does this mean anything, or is it normal operation.
07-10-2008, 12:04 PM #19
Thats not normal operation.
Something not quite right.
If I let my place get to 80, and then turn the stat to 70, it will run non stop till it reaches 70.
07-10-2008, 12:04 PM #20
- Jun 2003
- 115
I forgot, I do have some air leakage in a basement register. Basically, a previous home owner put a pretty large register on the main ductline facing downward to heat a portion of the basement space during winter. The register is closed but does not prevent all the air from coming out, so there is some leakage of air out of the register even when it is closed b/c it is old and doesn't close very well anymore.
07-10-2008, 12:08 PM #21
- Jun 2003
- 115
this is my dilemma in a nutshell. There is something not quite right with the system, it is oversized, etc...
BUT, the house is comfortable, the wife never complains and the house is nice and cool in the summer.....
So I don't know whether to spend money and time to fix it or just leave well enough alone....
07-10-2008, 12:16 PM #22
Measure your humidty in the house.
if its close to 55%RH.
Then a proper sized A/C,HP, will remove more humidity, and perhaps allow you to set the stat higher, and save money on your cooling bill.
You must determine when and where you want to spend your money.
And how much to who.
The oil company. The electric company.
07-10-2008, 12:50 PM #23
- Apr 2008
- 22
What should his humidity be reading?
07-10-2008, 01:04 PM #24
55% or lower. At 55, your on the high end of normal human comfort level.
In my place. 72°F and 48%RH feels cooler then 68°F and 55% RH.
07-10-2008, 01:16 PM #25
- Jun 2003
- 115
07-10-2008, 01:20 PM #26
- Apr 2008
- 22
I keep the thermostat at 72 F with a relative Humidity reading of 49-50% this is on the first floor, the second floor the humidity falls in around 53%.
I think my unit is slightly oversized but I have learned to live with it.
