Results 14 to 23 of 23
Thread: help with Carrier models
07-16-2008, 10:20 PM #14
Professional Member*
- May 2007
- DC Metro area
- 3,223
More surface area = warmer coil = less humidity removal (typically). Correct me if I'm wrong...
Can you provide the model numbers of both units to compare specs?
07-16-2008, 10:59 PM #15
I would think coil temperature would be close to same. But you would get more air passing through meaning more humidity removal. Correct me if I am wrong.
Do it right the first time.
07-16-2008, 11:03 PM #16
- May 2007
- DC Metro area
- 3,223
Well, from what I have read here, it seems that the general opinion is the larger the indoor coil, the lower the latent capacity typically (I guess it would be necessary to look at the technical specs for each matchup for latent and sensible capacities). Hopefully someone else can confirm.
07-16-2008, 11:46 PM #17
Trying to see if the is something on RSES manual or website but can't see yet.
07-17-2008, 12:43 AM #18
- Jul 2008
- 7
Model numbers
While I could go with Carrier proper, I am thinking of going with Payne (which as I understand is the same manufacture, just different labels and cheaper).
For Carrier it would be:
I/U = PF1MNC025/FY4ANF024
O/U = 25HCA324 (presumably 25HCA318 for 1.5-ton)
For Payne:
I/U = PF1MNC025
O/U = PN3AN024 (PN3AN018 for the 1.5-ton)
So, the proposal is to use the bolded models above.
07-17-2008, 01:08 AM #19
07-17-2008, 10:25 AM #20
- Jul 2008
- 7
07-17-2008, 10:34 AM #21
Latent capacity is the moisture removal abiility.
If you decrease latent, you usually increase SEER, but not always.
And in humid areas, people tend to set their stat lower if teh humidity in their house is too high. Meaning they use more eletric to feel comfortable. Losing any savings they would have gotten.
On a HP in heating mode. You get extra BTUs. But, with a time and temp defrost board, you could end up with extra defrost cycles. Which would lose you your savings at temps under 40°F.
Coils should be matched for best performance to the load calc. Not just increased in size because it was heard it will improve SEER.
07-17-2008, 02:14 PM #22
- Jul 2008
- 7
Help with HP sizing
It sounds like you are suggesting to just either go with a 1.5 or a 2-ton rather than mixing I/U and O/U. Frankly, that seems to make more sense to me too.Coils should be matched for best performance to the load calc. Not just increased in size because it was heard it will improve SEER.
It is just confusing when so many people are saying different things.
Maybe I just need to ask this guy to do the Man J calculations.
He wants to put in the 2-ton, and the only real reason he wants to downsize the O/U is to make sure it fits through the roof hatch.
I think the 2-ton would fit through anyway, but like I said before, it sounds like 1.5-ton system is more appropriate for my apartment. That is based on what I've heard here.
At this point, my only concern is whether mixing the two sizes is bad. So far, no one has really come out and said that -- only that it would be better if they were matched.
07-17-2008, 04:07 PM #23
Common for many brands to use a 1/2 ton larger rated indoor unit.
Not all brands though.
SAo, depending on which brand, its fine.
