Page 9 of 9 FirstFirst ... 23456789
Results 105 to 107 of 107
  1. #105
    Western NC
    Quote Originally Posted by BigJon3475 View Post
    I'm stuck on the dollar trick.....it's amazing how many times the dollar will just sit there happily.
    What dollar trick are you referring to?
  2. #106
    It's a broad generalization..
    If you place a dollar on the outside condenser and it's clogged the direction the air takes keeps the dollar planted to the motor housing. If it's clean it flies away....something to do with SP...Be prepared to chase your dollar on newer systems...
  3. #107
    Your trapped in an HVAC/R world when....
    You wake up thinking about how well a customers system is doing...can you do anything to improve it.....
    You walk by condensers and listen carefully for symptoms...
    You really really really want to go to the 1 of 11 sky scrapers being built within 3 miles of you and admire the instillation...
