Results 14 to 20 of 20
Thread: Three Fuel ?
    Most of that dust will go through the dry coil.
    If it was wet, then more of it would stay on the coil.
    Jun 2007
    Bucks Co PA
    Ok, learning time for a homeowner. At what OD temp is a HP defrost necessary??
    Depends on outdoor humidity. And varies with the HP a bit.
    Generally under 40°F. but once in a while it can happen above 40.
    most homes in Bucks county have a plenum on top of the furnace which feeds a tee and goes in both directions to feed the conditioned space. You could easily install strip heat in each side of the tee, and interlock those so that on a call for defrost, these are enabled, and controlled off of discharge air temp. These could be staged for better control, or even done with an SCR if you want to get real fancy. Depends on which part of bucks you live in and how big your lawn is I suppose.....
    I'm trusting the EAC's to keep the strip heaters clean
    One problem with the strips before the evap coil is that then I can't use it for reheat.
    PHM
    No, but pre heat can still increase humidity control.
    Dec 2006
    Middle Tennessee
    i seem to remeber a lot of your posts about reheat (i assume for dehumidification) or to cut down on system cycling
    strip heat makes for some very expensive reheat
    you ought to look into heat pipe technology
    it cost zero to operate heat pipe reheat!
    i used to be involved with the installation of heat pipes in miami fl.
    look at this link for kicks, its very interesting, of course initial installation is a bit pricey
    http://www.heatpipe.com/
