Results 14 to 26 of 173
Thread: $900 Electric Bill?!
07-09-2008, 12:02 AM #14
- Dec 2006
- Dallas
- 189
Take a look at this:
http://www.nppd.com/My_Home/Services...calculator.asp
Per: http://www.hvacopcost.com/
Use 2803 Cooling hours for Houston.
For KWH cost, make sure you divide the KWH on your electric bill with the final $. This gives you the true cost per KWH after taxes and fees, fees and fees, because that's what you really care about - Not the KWH cost on your bill.
Your house is not exactly small. Your electric rate sounds much higher than average. Yes, your systems are oversized. I think your bill sounds about right for the info you provided (It doesn't sound like the heat strips are on because the added loss would be double). A single story 4216 sq ft house has a lot of surface area to gain heat with. Replacing two 2 year old systems with smaller systems would probably have a 20+ year return on investment.
I would look at some fancy ductwork to twin the systems to have one system as the primary (with a higher cooling setpoint), and the 2nd system (with a lower cooling setpoint) running on a separate thermostat with large hysteresis to come on when the main system can't maintain it's set point. That's just me. I don't think many HVAC companies would be able to properly re-design and alter your ductwork for this. This wouldn't necessarily yield the greatest comfort for when 5 tons wansn't enough, but the 2nd unit would probably only cycle on and off for 3 hours during the hot season. I'm just thinking out loud.
07-09-2008, 12:12 AM #15
- May 2008
- North Texas
- 105
Yee gads.
10 tons at 13 seer draws about 9231 watts. 30 days at 12 hours a day is 360 hours. That's 3323 kwh at 17 cents for $565.
4 tons at 14 seer, 3428 watts. 30 days, 12 hours, 360 hours. 1234 kwh for $210.
Difficult to know the real run time on your current setup, but short cycling on and off means that moisture is not removed. A lot of the moisture on the coils is vaporized right back into the living space.
How many kwh did you use in march or november?
Heater strip as in aux heat for heat pump.
For sure get another Manual J on the as-built house before selecting new equipment.
07-09-2008, 12:48 AM #16
- Jul 2007
- N.C.
- 693
It would cost but with zone control and the afore mentioned duct re-design you could make this system work. I would see how far the installer is willing to go to help you get straightened out.
07-09-2008, 07:51 AM #17
First of all you didn't cave !!! Your HVAC broke the law!
Our SOS License Board is full of Suspensions and Fines from situations just like yours.
I would suggest you remind him of this before you file a complaint.
If you had a Manual J done and he didn't.... He is in big trouble if you file a complaint.... He will loose his license..
If you don't remind him of this, you than have caved...
I am personally conditioning 12,200 sqft with only 5 Tons $180.00 and month And I have an all foamed home/ roof as yours and my RH avg. 45% at 76*
Next can them dehumidifier... let your HVAC do its job..
Good luck
07-09-2008, 08:16 AM #18
- Feb 2002
- Houston Tx
- 344
I live 25 miles from Galveston 3500 sq ft 3 tons cooling foam attic and ICF walls. ALL electric 2 hot water heater 3 fridges, hot tub, well pump, septic, kw useage per month averages 2000 kw....... I trusted my HVAC guy that was ME
07-09-2008, 09:46 AM #19
If you have any circulating pumps for your hot water - turn them off.
The dehumidifiers should not be needed during the summer months.
Make sure any replacement systems have variable speed blowers - and I highly recommend the Honeywell IAQ thermostats.
How is fresh air brought into your house?
07-09-2008, 10:06 AM #20
- Jul 2008
- 45
No recirc pumps for hot water. I have to run dehumidifiers in summer or the house is like a swamp. Hoping to fix that problem with pending repairs. New units will be variable speed - already made that clear to vendor. I will investigate the t-stats you mention.
Fresh air intake is set to operate 10 minutes per hour, I believe.
07-09-2008, 10:10 AM #21
10 minutes per hour, at what CFM rate?
07-09-2008, 10:15 AM #22
- Jul 2008
- 45
No idea. How do I find that out? Is that information on the contoller near the equipment?
07-09-2008, 10:25 AM #23
Only if they measured it when they installed it.
You might be bringing in too much fresh air.
Have the contractors check to see how much it is bring in.
07-09-2008, 11:10 AM #24
07-09-2008, 11:18 AM #25
07-09-2008, 02:27 PM #26
- Feb 2008
- Lucas, TX
- 103
You said you have on demand water heaters - on an electric house ?!
Aren't those things normally done with gas ? Otherwise you need something
like 60 amps to run those things. I don't know how long they run, but that adds up.
Hope you get some better results with the improved company.
Adam
