Results 1 to 6 of 6
    Oct 2007
    Aurora , Colorado
    side discharge condensor
    hello every one,does any budy makes sid discharg condensor like (38 HDR ) that carrier makes.is a tru wall pakeg unit .thanks
    Thru the wall package unit?
    Or thru the wall condenser?
    Oct 2007
    Aurora , Colorado
    thru the wall condenser what i need for residential application ,but i like to knew about the packag unit if you knew any. thanks
    Jun 2008
    west point, ga.
    Quote Originally Posted by massoudv View Post
    I"m not exactally sure what your saying but have you looked at rheem?
    Feb 2007
    Las Vegas,NV
    You've got two different threads going and all of your posts so far dont really show that you know too much about this game. Maybe you would be better off if you called someone in your area to give you some advice on this mess you are trying to straighten up. If you have been in this business for any amount of time, you should know what is available out there.
    NCP makes thru the wall condensers.
    A thru the wall package, requires a larger opening in the wall.
