Page 1 of 4 1234 LastLast
Results 1 to 13 of 47
    Service Tech's numbers...
    I have a Goodman 12 seer, 5 ton unit in a 2100 sq ft house with 9 ft. ceilings; house was built in 2000.
    Disch Press: 325
    Suct Press: 75
    Super: 8* F
    Sub-Cool: 13* F
    T-Indoor: 20
    Ambient: 109
    What exactly do these tell me?
    Apr 2008
    Alberta Canada
    What are you looking for
    Quote Originally Posted by mbarizona View Post
    Disch Press: 325
    Suct Press: 75
    Super: 8* F
    Sub-Cool: 13* F
    T-Indoor: 20
    Ambient: 109
    Your asking me? I thought you would know since you wrote them down.
    Do it right the first time.
    Well, first of all - that's you going to freeze to death soon
    You better bundle up.
    Obviously your unit is wildly oversized - if it can produce an 89 degree different to ambient.
    PHM
    When faced with the choice between proving that their opinion is correct and changing their mind to fit the evidence - most people get right to work on the proof.
    DC Metro area
    My guess is the "T-indoor" is the delta T, not the indoor temperature.
    I am the home owner, I am just reading this off of the service paper.
    Lancaster PA
    It means your stat is set too low.
    Without knowing air flow and ID detlas, it doesn't tell much.
    Bonehead question...what is a delta T?
    Jun 2008
    west point, ga.
    Temp. difference between supply and return
    Lancaster PA
    Is it working better.
    No. Same response - "Unit is working at maximum efficiency".
    No, "X is broken, need to fix it." Or "Unit is toast, need a new unit".
    Just bend me over, take my money.
    NW burbs of Detroit
    It's over 100* outside. Your unit is working beyond normal design range. Ontario design temp is only 90*.
    Seems like they say it's running OK
    Why do you want to know? Are you having performance issues?
    Those are the standard things which a service tech would check to verify that the system is working well.
    PHM
    Quote Originally Posted by hvaclover View Post
    Just a guess but I'm thinking Arizona....
