Results 1 to 13 of 17
    Sep 2006
    Increased life on compressor....?
    Been in the biz for 10+ years, I am installing a new R410A for my own house would putting a liquid solenoid on and letting it go into pumpdown mode when the thermostat satisfies would allow the compressor an easier time on startup thus allowing for less wear and tear on the compressor? Or would installing a crankcase regulator on the suction line be a better way?
    It's a Copeland Scroll compressor, I forgot if did or didn't matter if the scroll is under equalized pressures it would startup the same. That scroll would startup the same whether equalized or not.
    Thanks for your input!
    Tell me why you think these things will be an improvement
    Because it sure seems to me that both would do the opposite of your claimed intention.
    PHM
    Quote Originally Posted by bubbahotemp View Post
    PHM
    Yorkville Illinois
    I don't feel either application will prolong the life of your compressor. The suction regulator is designed to regulate in a multiple evaporator application. Making the system pump down is to keep liquid from migrating back to the compressor causing slugging. I dont feel in a residential application that would apply. A crankcase heater will protect from this migration in your application.
    You don't need to add any of that stuff.
    Just like a comprssor in a refrigeration system. Long run cycles prolong the life of the compressor of an A/C system.
    So don't oversize your A/C.
    If you want to increase the life of your compressor add HGBP
    Do not use a cooling thermostat and set the hot gas bypass valve for the space temperature you want. You will have to fidle with it at first but just set it lower to reduce the house temp or higher to increase the space temp. When you get it balanced - just leave it there forever.
    PHM
    Just install it as per the install instructions.
    if it does not have a crank case heater you can add one but the easy way to prolong the compressor is a proper install proper charge and service it annully
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by Poodle Head Mikey View Post
    Northen West By God Virginia
    Smile
    Why not install a AMANA 14 SEER with life time compressor warranty and not do anything but relax!
    Western NC
    Quote Originally Posted by webbheat View Post
    Cause he don't want a glorified Goodman
    Sep 2006
    Compressor life
    Thanks for replies, anyway thanks for the info on crankcase heater, I know most techs hate Goodman except home builders, but I got a good deal on it, I know shame on me, but it is a 14 seer. Other brands were 2X the price. I was told that a compressor has a easier time starting on a suction pressure that is lower than the equalized pressure on startup I sometimes like to Over-Engineer it, but probably I'm wasting my time.
    I'll probably just throw on a Heater and be done with it.
    Thanks everyone,
    Southern, CA
    Actually compressors start easier with balanced pressure. And It seems to me that a scroll would allow the pressures to equalize since they don't have valves, making the solenoid useless anyway.
    Quote Originally Posted by Coolmaniac View Post
    The old ones did. Thats why they would spin backwards after shutting off.
    Since they have a check valve now, they don't equalize if you have a SV, or balance post TXV.
