Results 27 to 39 of 42
07-06-2008, 05:20 PM #27
- Mar 2005
- Houston, Texas
- 11,646
07-06-2008, 06:16 PM #28
- Jun 2008
- west point, ga.
- 328
What a loyal customer to ask help for her a/c tech.
07-06-2008, 06:57 PM #29
- Jun 2008
- Monroe Ga
- 77
I was just giving a possibility. Not an answer. But that "Ants" thread was very amusing. "Marge" had some issues admitting she was wrong. Got to love being at "their" homes. They are the ones who makes us earn our paycheck!
07-06-2008, 07:02 PM #30
- Mar 2005
- Houston, Texas
- 11,646
07-06-2008, 11:20 PM #31
- Jul 2008
- 7
07-06-2008, 11:32 PM #32
- Apr 2007
- 6,286
See some HO's get the vibe here
07-06-2008, 11:45 PM #33
- Mar 2005
- Houston, Texas
- 11,646
07-07-2008, 08:47 AM #34
- Aug 2003
- 466
I would agree to have your tech suspect both the outdoor fan motor or capacitor as well as the thermostat.
You can actually be a big help with this one by noting the next time the cooling stops and the outdoor fan is not running to check the large refrigerant tubing that is covered with black rubber insulation to see if it is cold. If the outdoor unit is not operating and that large copper tubing is very cold, it is more then likely that either the outdoor fan motor of the capacitor is periodically failing. If this is the case, I would recommend replacing both the motor and the capacitor no matter which is determined to be at fault. Especially having been operating under such adverse conditions, either one failed would have severely damaged the other.
As for the Maple Chase thermostat, I have also found them to be more bothersome then they are worth. Erratic operations are usually the complaints. Maple Chase and Hunter thermostats seem to be the most troublesome of the consumer readily available thermostats. Lux thermostats used to be almost as bad a few years back, but Lux has done a wonderful job in making their thermostats much more reliable now.
07-07-2008, 08:53 AM #35
- Mar 2005
- Houston, Texas
- 11,646
Chances are that the M-C t-stat was a D I Y install, that being said,Brenda go to the home supply center and get one of the better/best t-stats they sell. You'll be miles ahead in the long run.
07-07-2008, 12:39 PM #36
- Jun 2008
- South,Tx
- 325
Test the fan motor at condenser
Have the tech put an "amprove" and check the measuring against the sticker of that particular fan motor.
Matt 7:12 The Golden Rule
"Do for others what you would like them to do for you. This summary of all is taught in the law and the prophets.
07-07-2008, 01:17 PM #37
- Mar 2005
- Houston, Texas
- 11,646
07-07-2008, 01:59 PM #38
- Jul 2008
- 7
Dear All,
I thought I would provide an update since there has been such a generous community response. My AC man came by this morning and I shared your comments - he was very impressed that I took the time to investigate matters on my own
He encouraged me to continue the discussion online and get your inputs into what he did next. He did not know that this online discussion group existed - I hope I did not embarass him
He removed the cover panels off of each outside AC unit. The larger unit (the one that is working intermittently) has a small circuit thingy near the 'relay'. The smaller outside AC unit does not have this circuit, even though they are the same brand and age, the smaller one simply did not have one!
He disconnected the circuit from the intermittent AC unit and reconnected the remaining wires the same way as the smaller unit. My AC man then turned on the intermittent AC unit and it started and has been running perfect since this morning!
He thinks the problem is that the circuit is bad and new one needs to be installed to be certain. He said to keep the unit running until he returns later today to install a new circuit because he says it does serve a purpose.
He agreed with you all about the thermostat and said he will replace them when he returns later today. My AC man also thinks there may be other problems that may yet need his attention, but for now, he will take it one step at a time.
I told him the ant story and he was rather amused.
B
PS This is rather like a detective story - what fun!
07-07-2008, 02:06 PM #39
sounds like a bad time delay......
could cause the symptoms you were describing.
have him look at contactor, many times a bad time delay will damage the contacts if it has been chattering.
