Thread: pump head
    pump head
    hi,
    dear friends, can u pls let me know from where to where i have to consider primary pump head and secondary pump head, what will be the loop for these pumps, i mean i have ahu in the floor chiller in the roof in chiller outlet line i have secondary pump and chiller inlet line i have primary pump. pls guide me.
    Western NC
    This is not a DIY site.
    If you are a pro, then get your post count up and apply for pro membership.
    Even if someone wanted to help.
    No one would have an idea from that non understandable description
    Apr 2002
    primary is from the loop through the chiller and back to the loop
    sceondary is to the building up to the top floor to the most remote air handler and then back
