Results 1 to 9 of 9
Thread: filters
07-04-2008, 09:57 PM #1
New Guest
- Jun 2008
- 3
filters
Hi all,is it better to filter at the returns or at the air handler.Thanks.
07-04-2008, 10:25 PM #2
At The Unit
Ducts leak and return is negative pressure.
Do it right the first time.
07-06-2008, 02:31 PM #3
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
If the return ducts are sealed,at the grilles ,so you can have much more surface area ,which will allow for better filters without as much pressure drop.
07-06-2008, 03:24 PM #4
07-06-2008, 04:01 PM #5
New Guest
- Mar 2008
- 11
filtering at th grill keeps your return duct clean.
07-06-2008, 04:20 PM #6
Filtering at the grille makes it easier to change the filters (in most cases)
07-06-2008, 05:18 PM #7
07-06-2008, 07:18 PM #8
At the grills is the best IMO(where mine are personally), unless you go with a media filter at the unit. Like stated, static is affected, so needs to be checked.
07-06-2008, 09:37 PM #9
New Guest
- Mar 2008
- 11
