Results 14 to 25 of 25
07-04-2008, 10:14 PM #14
Professional Member*
- Jul 2006
- Virginia
- 3,716
call for service could be clogged inside coil and also if the have not been serviced this year they should be
07-04-2008, 10:17 PM #15
One other thing.
Is that an N coil?
07-04-2008, 10:20 PM #16
- Jul 2008
- 11
07-04-2008, 10:22 PM #17
Post the model number.
07-04-2008, 10:43 PM #18
- Jul 2008
- 11
07-05-2008, 01:42 PM #19
Thats an N coil.
And if its installed that the right hand side has to have a block off plate, it tends to freeze.
07-05-2008, 04:08 PM #20
- Jul 2008
- 11
07-05-2008, 06:37 PM #21
- Jul 2008
- 11
dripping stopped
I capped the vent and the dripping stopped immediately!
Let me know if there are any other concerns any of you think I should explore. Everything seems great now though; thx for everyone's input.
07-05-2008, 06:41 PM #22
If you end up having poor cooling performance on the hot design temp days. The coil repositioned, may help.
07-05-2008, 06:55 PM #23
- Jul 2008
- 11
07-05-2008, 08:31 PM #24
stopped immediatly isnt imo a good thing. This teels me there may be two problems here
1= the drains are reversed like you thought at first and time to calll and have them checked
2= turbulents caused by high static is holding water in the tray. I have found on positive pressure coils if the static is high and there is a trap with no vent the turbulants can cause the air the hit the trp and then back up and hold the water in the tray till the unit turns off or it over flows
leave the unit on for a while then go pull the cap and look in the pipe if you see water suddenly gush out you need to leave the cap off and get some help from a tech. Alao he can trace the lines and make sure they are correctly ran. The fix for the static is a completely differant repair
a temp is to remove the trap or leave the vent
07-05-2008, 09:22 PM #25
- Jul 2008
- 11
I left the cap on for approx. 4 hours with the unit running, pulled it off and no water gushed out, just some cool air. I re-capped it but will pay attention to the situation with your advice in mind. BTW the drain tray is dry. Thx tinknocker service tech
