Results 1 to 13 of 16
    Harmony Zone Controller without variable speed
    Hey Folks. I am looking for some Harmony zone controller experience. To sum up a long story, I need to get the Harmony working with a nice dual stage Lennox condenser but a three speed blower in the air handler, not variable. Will essentially be using an older air handler where cooling currently uses fixed high speed, heating uses med speed and low is unused. I know that the Harmony uses a voltage control to tell the air handler where to set the blower, but there must be a way to operate two or three speed blower based on demand level from the Harmony.
    So to reiterate into a question, can the Harmony be configured to operate a two or three speed blower?
    Western NC
    Quote Originally Posted by kazko View Post
    Your Frankenmonster will give you nothing but problems....
    The 2 speed or dual speen condenser is designed with a varible speed air hanler, not multi speed.
    And the harmony works with variable speed blowers, not multi speed. Wont work, your ideas are far fetched.
    Get the system installed properly by a contractor. A contractor that will install matching components.
    May 2002
    Houston Texas
    In a word NO!
    Arizona
    What he said! You are looking for nothing but big problems.
    leland nc
    it wont work complete waist of time
    Would be some awlfull rigging if you got it to work at all.
    You won't have humidity control because the blower won't slow down when in first stage.
    So your customer will have spent a lot of money on a comfort condenser, that isn't providing comfort. And may end up using more electric, then they did with their old unit.
    Tell them you can install a nice VS blower air handler, or sell them a Single stage condenser.
    burlington county n.j.
    it could be done but it would be a pita to set up.
    could control blower speed with a slave relay tied into condenser control circuit.
    no way to control heat blower speed and it would probably need bypass damper or a dump zone.
    discharge air sensor to control compressor stages.
    Jun 2008
    west point, ga.
    Like my boss tells us "DO IT RIGHT OR GO THE HELL HOME"
    So I say no.
