Results 14 to 21 of 21
    Jun 2007
    Round Rock
    There is no true max.
    Yes, my unit is over sized by many peoples standards.
    But with some tweaking. It works the way I like it, and keeps my humidity under 50%.
    The amount of time I have setting it up. Most people wouldn't want to pay for.
    Not to rub it in too much.
    But if it was 100 out, I could get my place down to 70. I'd have to bring my blower speed back up, past 400 CFM per ton though.
    I barely do 320 per ton now.
    I tweak on mine too, depending on what the outside temp is. Right now I'm running at about 1100 CFM for a 3 ton. It's 100 everyday here. When its in the low 90's and 80's. I'll get it down to about 900 cfm for my 3 ton. It works great, lowers the bill substantially and controls humidity great. It's a Trane 80 furnace, variable speed with 3 ton coil matched to a 10 year old Janitrol. Runs like a champ. I know its mismatched, but I do it for a living and it works great.
    I'm at 800CFM for 2.5 ton.
    Quote Originally Posted by Clorox View Post
    1) I should have gone to 3.5 tons.
    2) I should have added a return vent in my hallway, right above my thermostat. (suck the trapped heat out)
    Matbe the return.
    But doubtfull on teh 3.5 ton.
    Just call your contractor so he can come out and fix whats wrong.
    I have 2.5 tons for 1650 sq ft. But I got shade.
    May 2008
    Call the contractor......it's their problem. And 73 for the cooling is about perfect.....wonder what Mr. Bill keeps it at during heating season?...80?
    A difference of 26 degree's? How? Oversized? Too much freon?
    I thought a differential of 20 was the max?
    20 is the norm,but what it's designed to do is the max,down to a point.
    Jun 2008
    Unhappy
    5:00pm 2nd floor, bedroom doors open
    outside = 87
    inside = 74 (lowest possible)
    difference = 13
    7:00pm 2nd floor, bedroom doors open
    outside = 84
    inside = 72 (lowest possible)
    difference = 12
    9:00pm 2nd floor, bedroom doors closed
    outside = 80
    difference = 8
    10:30pm 2nd floor, bedroom doors closed
    outside = 74
    inside = 71 (lowest possible)
    difference = 3
    Looks like regardless of outdoor temp, inside will not drop below 72?
    I hope you already placed your service call.
    You don't want to be running it with a low charge and damaging and voiding your warranty.
    May 2005
    Lake County,Illinois
    68 in dead of summer
    There are two customers who keep their t-stat set to 68 in the summer cause they like it cold whn we did the install we went to a five ton from a four ton added more return and supplies i cant believe it when ive gone there program set to 68 and customer has no concern friggin thing must never shut off!
