Results 1 to 13 of 21
    Jun 2008
    Unhappy Difference of only 13 degree's at 5:00pm
    86 Outside and best Inside temp is 73. (2nd floor)
    Difference of only 13 degree's?
    New system, 3 ton Trane. (been running all day non stop)
    6 returns and 10 supply vents.
    R410a
    1800 sq feet
    Suggestions?
    Houston,Tx.
    Who in the world needs it 73 in there home? are you storing bodies in there? we would need to know the wet bulb to really be able to tell you if that split is ok, it's very possible you could have enough outside air penetration from outside into your home that the dew point is way up.
    LOL..
    When it was 98* a couple weeks ago, I kept my place at 72*
    Nice and cold.
    Call the contractor back. Could be charge isn't right. Duct not sealed right. Not wierd right.
    You just had them installed, they're under warranty.
    Jun 2008
    south central pa
    call the company who installed it you have a problem. im guessing you went with the trane 410 setup. watch for the indoor coil freezing or condensation on the metal of the cabinet. if that happens shut the unit down. and if it happens to be the txv post back with their super heat and subcooling readings.
    I prefer no higher than 74.
    Houston,Tx.
    Quote Originally Posted by acobra289 View Post
    You folks ain't right!
    Jun 2008
    A difference of 26 degree's? How? Oversized? Too much freon?
    I thought a differential of 20 was the max?
    Jun 2008
    What is the wet bulb?
    Air penetration, could be.
    Explain how the dew point works?
    Feb 2007
    Las Vegas,NV
    Right now, my evap cooler is holding the house at 73, if it goes above that, we turn the a/c on. I like my house cold! I have neighbors that keep their stat at 80. I sweat to death in their house.
    Quote Originally Posted by Clorox View Post
    There is no true max.
    Yes, my unit is over sized by many peoples standards.
    But with some tweaking. It works the way I like it, and keeps my humidity under 50%.
    The amount of time I have setting it up. Most people wouldn't want to pay for.
    Not to rub it in too much.
    But if it was 100 out, I could get my place down to 70. I'd have to bring my blower speed back up, past 400 CFM per ton though.
    I barely do 320 per ton now.
    Houston,Tx.
    Maybe some folks want to keep as cool as possible here on earth because were there going there will be no a/c, just kidding.
    Jun 2008
    1) I should have gone to 3.5 tons.
    2) I should have added a return vent in my hallway, right above my thermostat. (suck the trapped heat out)
