Results 1 to 13 of 33
    New to forum and needing advice
    I hope my request for help doesn't violate the site rules, but I think I need the advice of a professional, and this seems to be the place to find them.
    Our five year old A/C unit went out (nothing would come on) this past weekend and to make a long story short, the tech that came out claimed that after he blew the transformer he had just replaced, he realized the problem was actually a bad controller board, a Carrier HK42FZ013. This was this past Sunday. He was to return on Monday after he got a new board and and new transformer.
    He arrived late yesterday and proceeded up to our attic. I was already a bit suspicious, but my instincts really started flairing when he was in our attic for almost two hours replacing it. Access to the controller board is fairly easy on our Carrier 58STA070, so I couldn't understand what the problem was. He finally got the unit operational, I paid him and then asked for the old board. He first told me he had already taken it out to his truck, and when I said I'd like to have it, he refused, saying he couldn't let me have it - company policy. We were still inside the house and I could see the box on top of his tool bag despite what he had said and, well, I took it and refused to give it back to him. I figured it was still my board, whether it was a dead one or a live one. Of course my suspicions deepened as he insisted I return it to him or he was going to go up to our attic and remove the "new" one. I was polite, but explained to him that that simply wasn't going to happen and invited him to call his boss or we could call the sheriff, but he wasn't leaving with my control board. I have the board.
    My suspicion is that I now have in my possession a perfectly good control board. I even wonder if I am holding the brand new board that, after discovering it wasn't the problem, he continued to trouble shoot. That's the only reason I can figure why he was so adamant about leaving with it (and perhaps cover himself in the process).
    Anyway, I am hoping somone here can offer me some guidance on what I can and should do at this point.
    Regards,
    Scott
    Western NC
    you need to remove your prices....
    But your situation definately raises a red flag....
    I would call the contractor in the morning and speak with the manager. Explain that you are unsatisfied with the service and would like a partial refund. You may not get it all back but you may get some.
    And get a new contractor. Personally, I have no problems leaving failed parts with HOs that want them (provided its not a coil or compressor).....but a contactor or board....sure you take it. Less trash in my truck.
    The fact that he didn't want to give it to you is a little off. You may in fact be holding a new board.....If you want, you may be able to contact Carrier or the supplier and read them the model off the board. It may lead to some interesting information.
    I'm sure others will be along with thier two cents. But thats mine for now. I will probably chime in later with others.
    parts changers change parts....technicians fix problems...you get what you pay for F.Y.I. i always offer customers their defective part
    Quote Originally Posted by dezerttech View Post
    Jun 2008
    Phoenix, AZ
    scott open that box and tell me if it has a purple spade fuse that you would find in a car... should have a number 3 on it.... purple fuse with number 3
    Jun 2008
    Phoenix, AZ
    Cool
    I cant find the schematic on that unit at the moment, but I'm sure that board has a spade fuse. If you have a short in the low voltage system like a crimped t-stat wire then the spade fuse will blow. Your transformer shouldn't have blown, let alone the board go bad. I made the mistake of putting in a 5 amp fuse into that same board and blew the transformer because there was a direct short in the t-stat wire. Hard to say exactly what the problem really was but for someone to make that big of a stink about a control board. You can also look at all of the spade connections very closely and be able to tell if that board was even installed. One main way to see if you had a problem with the t-stat wire is to look at the wires. He might have changed one of the wires to use another one because there was a short. You said he went in the attic for awhile did you ever notice him changing wires at the T-stat or in the outside unit? Too many scenarios I can think of ... goodluck, hope it helps
    Five years,the board could have been under warranty still.But your tech should have explained that if it was. I have gotten boards that aren't an exact change out that took some time to modify, so two hours isn't too far out of line ,if in fact this was the case.
    Dec 2006
    Middle Tennessee
    i can't get my customers to take the old parts that i have replaced, they always say throw it away
    but i always offer to give it to them!
    the tech. may indeed of needed to return it for warranty
    normally you will be told if the part is under warranty ahead of time!
    If teh board is under warranty, then they would need to keep it to return it for warranty.
    If they claim it is not under warranty, then there is no need for them to keep it.
    I would suggest you call that company and talk to the owner, general manager, or service manager, and tell him what you suspect, and why.
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by dj3901783 View Post
    what if it does?
    what if it does not?
    Quote Originally Posted by Airmechanical View Post
    what if it does?
    What if it has an E instead of a 3.
    Yes, dj3901783, there is a 3 amp [ or an E or W or an M to some of you ] car fuse just to the right of the contact screws along what I would call the bottom of the board, if oriented as to read the printed labeling.
    That fuse looks to be fine.
    As for board itself, It's hard for me to detect any evidence that the spade connectors have seen any use. There is one that has a plastic cover on it that when removed looks exactly like the others.
    Is there any easy way to find out who the local Carrier distributor is and do you think they might be able to help? I spoke with Carrier Corp yesterday, and didn't find them very eager to get involved.
    Unless you can see a manufacture date. You still don't know if thats the new or old board.
