Results 1 to 13 of 15
07-01-2008, 10:28 PM #1
- Jul 2008
- 20
Need help making decision on Lennox
A neighbor of mine is a HVAC tech and he has offered me what he told me was only used for about 1-1.5 years a Lennox 3 ton AC. He dropped it off tonight and I looked at it. It seems very clean, but after looking for information on the web for the model, it seems to be much older then that.
The model is 10AC36CDN-1P
Does anyone know the last year these were sold? He said he removed it from a customer about 2 years ago and it was 12 to 18 months in service, so that dates it to roughly 2004-2005. From what I see these units entered service back in 1993, so is it possible to have bought one in 2004-2005 new?
Thanks, I don't want to install such an old unit just to save some money, albeit considerable.
07-01-2008, 10:36 PM #2
- Mar 2008
- 657
need a serial number to tell you the age.
"The things you own end up owning you. "
Tyler Durden
07-01-2008, 11:08 PM #3
10acc model started arround 2000
before that it was 10acb
it is free or cheap so use it
07-01-2008, 11:20 PM #4
- Jul 2008
- 20
Actually it's the 10AC not 10ACC...and it's not free nor cheap.
***Pricing removed***
Where can I find the serial number?
It the Lennox Diplomat model BTW.Last edited by NickDarios; 07-01-2008 at 11:40 PM.
07-01-2008, 11:31 PM #5
serial # should be on the unit data label.
diplomat was the cheap builder model.
pricing must be removed from your post but i would not pay that for it........
07-01-2008, 11:43 PM #6
I wouldn't pay for a new Lennox yet alone a used one
Note to disclaimer:
Personal opinion of member. In no way was this an attempt to brand bash. So don't loose your marbles. It was just a joke. Not to be taken seriously. Merely for comic relief.
07-01-2008, 11:49 PM #7
- Jul 2008
- 20
There is no serial number there.
07-01-2008, 11:54 PM #8
then it musta wore off.....which means its either really old or your looking at the wrong spot.
It shoud be right there below or beside the model number. If there really isn't one, look down inside at the compressor and try to get the make, model, and serial of it.......That would give us an idear too.I fully support the military and the War on Terrorism.
07-01-2008, 11:59 PM #9
- Jul 2008
- 20
No it's not worn off. There simply is no serial number listed there. The compressor is enclosed from what I can see with I guess some sound proofing?
It's a 10AC36CDN-1P. Lennox site doesn't even have old archives on it.
The only manual I found online was printed in 1993 (http://www.hvac-direct.com/pdf_files/service/9307.pdf)
Really I needed to know if it was possible that this machine was purchased new around 2004, but from what I am reading, it's unlikely. I am calling him first thing in the morning to cancel the install and for him to come and pick up the machine.
07-02-2008, 12:10 AM #10I fully support the military and the War on Terrorism.
07-02-2008, 01:08 PM #11
- Jun 2008
- 19
Another Lennox question, I see a lot of Pros here, thanks !
If I have to choose between new Lennox G61MPV60-90 and G61MPV60-110 fournace, knowing that my total house area (w/o basement) is about 2,600 sq.ft., and with basement about 3,250 sq.ft (garage non included), and that house is built in early 80-ies, when they used to use 2x4 instead of 2x6 for external walls (ergo: my external thermo insulation is not the best), what is the better choise ?
Contractor "A" says, that 90,000 BTUs are good enough for this area, and that first stage delivering 60K BTUs will do the job, if not second stage of 90K for colder days will be OK (lets say we know that 90,000 are in reality 84,000),
Contractor "B" says, that it will be better to get a 110,000 BTU fournace, so we will be always sure that if first stage of 90,000 dosn't deliver all juice, second stage of 110,000 will do it. Especialy if price difference b/w both models is not too big ... I don't know how much exactly, anuways ...
But my question in this case is : knowing that a 110K fournace will always start from 90,000 and not from 60,000, is it a good choice ? (more gaz I believe for 90K first stage against 60K == more money spent, but for shorter time lap ??)
Anyone to post a word, PLEASE !! ;-)
Thanks!
07-02-2008, 01:13 PM #12
- Jul 2008
- 20
Since you hijacked my thread, I'll hijack it too...do you know a good installer for A/Cs in the Montreal area? I have a great deal on an A/C unit from Ontario but now I need to find someone willing to install it.
----end of hijack----
07-02-2008, 01:22 PM #13
- Jun 2008
- 19
Thanks for hijacking it ;-), seriously - sorry if I cause you a problem, but topic was too close in terms to mine...
I could give you a name and phone of one I know on south shore - St-Hubert, I didn't work with him but I have good feed-back from friend of mine. M. Serge Desrosiers, 450-656-1733. Is that fine ?
