Results 1 to 13 of 20
    Jun 2007
    Tennessee
    trane unit freezing up?
    We installed a new A coil two months ago, and today we were called back. WE when got there the indoor coil was frozen, so after thawing the coil out we checked the freon pressure 240psig and 88*f 70psig and 68*f. These reading do not add up at all. one is saying the unit is way overcharged and the other is pointing towards under charge. The coil is a new trane coil with TXV. The upper section of the coil was for some reason not cold. Any ideas would help, since i'm going back tomorrow. I think the TXV is not working properly.
    Philadelphia
    Quote Originally Posted by david24 View Post
    Neither of them pressures suggest you are overcharged. neither of them suggest you are undercharged. call a pro.
    Jun 2007
    Tennessee
    Quote Originally Posted by d_griff View Post
    we had a 20* sub cool and a 30* superheat on a txv system... with a head pressure of 240... That's not a indication of overcharge..hahaha you are certainly not a pro.
    Nov 2000
    Eastern PA
    We do not care to discuss this sort of issue in an open forum. Please apply for professional membership so this can be discussed in one of the closed, professional technical forums; http://hvac-talk.com/vbb/showthread.php?threadid=116113
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    might be a restriction on the liquid line dryer
    petaluma,ca
    could be a bad txv or maybe the wrong txv for the r-type, if you end up replacing the txv replace the filter\dryer while you have it pumped down just in case, dryers are cheap.
    Philadelphia
    Sorry, I cant believe i have been showing up for work everyday for a decade fixing these things. thank you for letting me know.
    Dang. I wouldn't take those readings as an over or under charge either.
    Guess its back to school for me.
    Philadelphia
    Im not going to work tomorrow
    Im going to computer school maybe.
    I think I'll go to school to become a brain surgen.
    Philadelphia
    Brain Surgeon??? I dont know man, If we couldnt get this A/C stuff down maybe we are getting ahead of ourselves with these jobs...
    Maybe i will go for stockboy at the local hardware giant.
    But if I become a brain surgen, and screw up, the way I figure it, the patient ain't gonna be able to complain.
    Philadelphia
    good thought..
    In that case I'm going to become the first drunk brain surgeon .....
    ... Now if i only knew a refrigeration mechanic to keep my beer cold
