Results 1 to 13 of 22
    Should I get the Spaceguard 2200?
    I am going to be getting a new HVAC system. (See below for specs) Should I get the spaceguard or just go with a normal 1" filter? My 2 main concerns are price and airflow. I am already probably spending more than I should, so I don't know if I should spend the extra to get the spaceguard. I have also read that these type filters can significantly reduce the airflow. Is that a legitimate concern?
    Should I get it or not? Thanks.
    Trane XR13 Heatpump 3 ton 4TWR3036A1
    XT-90 furnace 80k btu TUX1B080A9H3
    coil 4TXCB036BC3
    ARI# 1231123
    Did they check to see if your duct is sized to install one with out restricting air flow too much.
    I agree. Duct has to be checked for correct sizing. I have seen many Spacegaurd 2200 installed that should not be.
    Atlanta GA area
    I run a small company and generally custom design each system to the needs of the customer. I recommend either an AirBear or an AprilAir (Spacegaurd) when I do an install. Here are some reasons:
    1) Cleaner air to breathe. What price would you as the HO that lives in the house, place on breathing cleaner air all the time you are at home? That includes every night when you are sleeping.
    2) Less dust to clean up when you do the (hopefully) weekly housecleaning. Many of my customers have said they have less dust.
    3) Here is one that many folks have to think about for a while: The equipment will last longer with a better air filter. Simply: less dust gets past it, and there is less back-pressure--resulting in more efficiency.
    4) less changes of the filter. If the system is not in an easily accessible place; media or spacegaurd filter systems usually need changing twice a year (or sometimes less, depending on system usage).
    I would recommend it! What part of the country do you live in?
    GA-HVAC-Tech
    Thanks for the responses guys.
    I live in Winston-Salem NC.
    A lot of my duct work work is in the garage portion of the house, so it's in plain view. As far as I know, no test or anything was done to determine if it would restrict the airflow too much. Is that something that can be determined just by looking over the duct work? Or does all the duct work have to be measured for both length and diameter and then calculations done based on that?
    Thanks again.
    Atlanta GA area
    The SpaceGaurd has roughly an operating (air flow) opening of 23x18 (inside of the mounting flanges on each side). It will easily flow 4 tons of cooling, albeit some folks install it on a 5 ton system (I would use 2 spacegaurd units on a 5 ton system). Given your replacement system size of 3 tons, I think the only problem you yet have to solve is if it will physically fit in the space. But that is for the HVAC contractor to do.
    Enjoy the clean air when your new system is installed.
    GA-HVAC-Tech
    Apr 2001
    Camel City, NC
    Small World
    Quote Originally Posted by acobra289 View Post
    That makes 2 of us.
    I have a (spaceguard) Aprilaire on my system and recommend them on equipment I install too.
    Be safe not fast. body parts don't grow back
    Quote Originally Posted by selfemployed View Post
    That makes 2 of us.
    Howdy neighbor!
    Just curious, do you work for a local company or are you really self employed?
    Apr 2001
    Camel City, NC
    Howdy neighbor!
    Yes I am. Worked for the GE/Trane dealer located in downtown W-S 27 yrs. ago.
    Jun 2008
    Florida
    Your HVAC contractor should be able to tell you about your duct sizing. It is just a matter of a quick calc. I would think they already know but do ask them and voice your concerns.
    As far as should you get a "space-guard" or a 1" filter go with the space-guard type style(5" filter). I suggest because you are getting a Trane they offer a filter called "perfect-fit" it fits right on the bottom of your unit perfectly ----hence the name. It is a bit more $$$ than aprilaire,space-guard etc. but, it is a neater look I think.
    I have a couple questions --
    You are getting a furnace? Why are you also getting a heat pump? The furnace should be enough? The condensing unit should be a 4TTR3036 for a straight cool.
    Quote Originally Posted by Shark207 View Post
    I use propane and the cost is getting outrageous. Our electric rates are very reasonable in NC, so I want to use a heat pump for most of my heating and have the furnace as the backup on the colder days.
    There is a chance I may be able to switch to natural gas. The local gas company is currently doing a feasibility study to see if they will run me a line. But either with NG or propane I am still going to use a HP for my main heat source.
    Atlanta GA area
    What kind of dual fuel controller is the installer using? If you are installing a single system with single T-stat, I would suggest you look at the Honeywell IAQ (9421) T-stat.
    It will act as the dual fuel controller, as well as humidity and de-humidify, 3 stages of heat and 2 stages of cool, and ventilation.
    Let us know how the system works out after it is installed... and pictures! We like pictures!
    GA-HVAC-Tech
    Dec 2006
    Northern VA
    The spaceguard is worth the money spent on it. Remember, it's a long term investment.
