Page 1 of 4 1234 LastLast
Results 1 to 13 of 51
    Jun 2007
    North Texas
    Condensate drain (s)
    My main condensate drain is working correctly (just got new system) but I still have +- an inch of water in the emergency drain pan and it is flowing out. I didn't think the pan would be draining water except if the main drain failed. Can you set me straight? Live in hot humid Dallas TX.
    Thanks,
    If the main drain is working right, how did the water get in the emergency pan.
    Jun 2008
    Dudley, North Carolina
    Is the end of your condensate drain line flowing freely or in the dirt? The clog may not always be in the drain line itself but at the end of the line. Best thing to do is look to see if if your line is dripping from outside. If it is in fact dripping in ac mode then the challenge is not your line.. If it was me I would install a pvc union, blow out the line with nitrogen, install an easy trap and float switch.. Hope it works out for you!
    Feb 2007
    It sounds like the condensate isn't all going out your primary drain, and is dripping into the emergency drain. What did your installing contractor say when he came out to look at it?
    "Press on. Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education alone will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent."
    Pictures would help.
    Jun 2008
    Florida
    After your installing contractor fixes your drain problem. (Sounds like your Coil is not "level" in the air-handler. Or the primary pan is cracked. Or connections in your pvc is not tight.) Have them intall a float switch in your emergency pan and a "SS1" or any style of "in-line" float switch in your drain line. These two items will shut down your system if you have drain problems in the future. Which will prevent any further damage.
    N.E. Ok.
    I bet your installing contractor would respond to a water in the emergency pan on a new system
    If in fact he is Licensed, insured and bonded.
    Jun 2008
    Florida
    Quote Originally Posted by captube View Post
    You got that right!!! I would be running to that one. And if it is in the attic. SPRINTING to it--Don't wanna buy sheetrock and a paint job for anyone.
    Houston,Tx.
    And NATE approved....
    Jun 2007
    North Texas
    I'll try to answer a few questions and attach a picture.
    I should have said the main drain is flowing, correctly was an assumption on my part, point well taken.
    Company is licensed, bonded and insured, one of the best in Dallas, employee owned.
    I believe I do have a float switch, see pic.
    The main drain goes to indoor plumbing and out to septic.
    Thanks for the comments.
    Nov 2001
    east kansas
    I don't recognize what they did with the trap. Or what kind it is. Is it one of those prefab with a switch?
    There is a red dial looking thing. Is the trap open to the atmosphere on the upstream side. We know the secondary trap is primed by now if it is leaking into the pan.
    We would be in a hurry to look at that install if we did it. Like said before, we don't want to buy a new ceiling.
    Beware of advice given by some guy on the Internet.
    Nov 2001
    east kansas
    Is the outlet of the trap capped? It should be open to act like a vent.
    N.E. Ok.
    Is the coil level ? Goodman gas furnace?
    TXV looks like spaghetti.
