Results 1 to 13 of 14
    Here's Our Quote Company "A"
    American Standard
    Heritage 16 SEER
    4A6H60484
    48,000 capacity
    Air Handler(S)
    2/4TEE3D49 4.0T (VS) R-410 A
    49,000 capacity
    or
    2/4TEE3C49 4.0T (SS) R-410 A
    49,000 capacity
    ACONT8027-Day Digital Programmable 3 Heat / 2 Cool T-stat
    Dual Fuel Furnace-
    AUX2B100AFV3VA 4T 60,000 ST 1
    93,000 ST 2
    Amana
    ASZ18 0601A Heat Pump 4 Ton
    57,000 Capacity
    AEPF426016 Air Handler (VS, mult-position) R-410A
    AMH95 0905DXA Duel Fuel
    The 18 SEER Amana is a SLIGHT bump in price over the 16 SEER
    The 16 SEER American Standard is a huge bump up in $$ over the 18 SEER Amana and gargantuan bump up over the 16 SEER Amana
    No mention of T-stat for Amana
    New Duct work (except for trunk)
    Extra Return (total of 2)
    Extra Supplies
    Larger Pad (if needed)
    Full Warranty
    Now company "A" is the company that's been servicing our HVAC this year and fixed the installers' screw ups. Trusted, reliable, and BBB certified
    Comments, thoughts, advice would be appreciated
    We will be taking other quotes later, but for now this will suffice.
    Jun 2001
    DFW
    Ask them for the Honeywell IAQ thermostat.
    One of the things I should have done when I had mine installed.
    Will do
    Read some good things about it.
    The A/S16 will require you to switch to gas heat sooner the the Amana's or the A/S18
    The TCON802 nor 803, can't control 2 stages of gas heat when used as a dual fuel thermostat.
    Thanx Been
    I'm really hoping to do away w/fossil fuel heat and simply rely on the heat pump and our back gas logs. I'm guessing if that is a main concern, I'll need to go w/the Amana 18 SEER
    You would still want an aux heat sourse in the HP for defrost.
    The Trane, A/S 16 SEER 2 stage HPs have lower BTU capacitiy at lower temps then virtually any other 2 stage.
