Results 1 to 7 of 7
06-29-2008, 05:27 PM #1
New Guest
- Jun 2008
- 0
Does york make a 18 seer 5 ton heat pump?
I was told after visiting York's website,where it shows the model 8 T 18 seer heat pump,that they no longer make this unit.
06-29-2008, 05:30 PM #2
Hey, one thread at a time, read the rules. I deleted your other threads.
Thanks for cooperating.
06-29-2008, 05:36 PM #3
Looking at the equivilent Luxaire (manufactured by York) Acclimate 18 SEER line, it looks like only the 3 ton version of this line is actually rated at 18 SEER. The 5 ton model is rated at 15.5 SEER.
Government is a disease......masquerading as its own cureEcclesiastes 10:2 NIV
06-29-2008, 08:35 PM #4
The 5 ton 5T has a higher SEER then the 5 ton 8T. And cost less.
Get the YZE, instead of the YZH.
06-30-2008, 01:00 AM #5
- Jun 2008
- Phoenix, AZ
- 70
if you go to York's website they'll have all the technical info you can ask for... the 5ton 8T Heatpump get up to 15.15 seer when properly matched so look around on the website for Luxaire stuff or maybe look at different mfr's to see who really has the highest seer equipment.
06-30-2008, 01:05 AM #6
The 5 ton 5T, gets 15.25 SEER. The 8T has no real benefit to it in the 5 ton size.
Just cost more for less performance.
06-30-2008, 01:05 AM #7
