Results 14 to 26 of 27
    Nov 2000
    Eastern PA
    A 15 year old Goodman system that is operating well under adverse conditions...well fancy that. There are some brand bashers on this site who will swear that your system cannot exist
    I would not put a lot of money or effert into any 15 year old system. The fact that this system has been operating with a leak, and is already 15 years old, tells us that it may already be operating on borrowed time. Any significant amount of money spent trying to repair it could well be just wasted.
    I would definitely not put a 2-1/2 ton system in a home designed for a 2 ton system that is doing the job as is. Oversizing HVAC equipment is one of the worse things you could ever do for comfort and efficiency.
    If you are having a R410a system put in, insist on the lineset being replaced and you won't have to worry that your current leak could be in it somewhere.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Western NC
    lol. Thats a post for tess...
    Go figure...they are gone now. Didn't even get the email. Oh well....I already got the contractor lined up for em and they leave.
    Jun 2008
    haven't left yet
    I'm sorry, just went off line because of lightning storms. Thanks for info.
    Quote Originally Posted by iraqveteran View Post
    Shoot me an email...
    I can give you a good direction to follow.
    Can't do it in the forum.
    Why not?Guessing I need to read the rules.
    Jan 2001
    Pamnyra VA.
    i use my drain water. about 5 gallons of water a day. no plants have died yet.
    Jun 2008
    skibme
    thanks, I'll keep using the drain water
    Jun 2008
    All Goodman bashers, come see me. My much older low end contractor's unit is
    operating well in Houston. Clean what? Lubricate what? Never has been serviced except once 2 yrs ago (added a bit of freon, so it may be nearing it's end of life). I'm only considering replacing it due to its age and possible energy savings with a new system.
    Sep 2006
    Angier, NC
    I live in Angier, a little bit north of you. Sounds like you would probably need a 2 ton. More importantly though, did either contractor do a load calc to determine what size or did they just guess? You need to find a contractor that will do a load calc and determine what size you need.
    Western NC
    Quote Originally Posted by deq1269 View Post
    I've already got her taken care of...Provided she uses the contractor I recommended.
    Western NC
    Quote Originally Posted by dash View Post
    Thats simple.......
    Its called CYA!!!!!
    Jun 2008
    Licenses
    Thanks for the information! Are there certain licenses you need to have to do your kind of work in N. Carolina?
    Quote Originally Posted by tuffynr View Post
    A/C condensate drain water is great for watering plants.
    It is not acisic. Unless your using chenicals in your house.
    Jun 2008
    water
    thank you, my son (installs solar panels and is also a general contractor) lives in the west. He told me that so maybe the water is different out there.
