Results 1 to 7 of 7
    Jun 2008
    inland empire
    Confused fastest way to pumpdown a split system
    what is the fastest way to pumpdown a system
    MN
    indoor fan off and just the condenser running.
    You can't fix stupid
    Wyoming
    Call a pro immediately, tell them you need it pumped down fast, sit back and let them do their job.
    somewhat of a strange question
    Sorry, just a bit too technical to answer in the open forum.
    Get your post count up, and apply for pro membership.
    Then you can get answers in the pro tech forum.
    Quote Originally Posted by cmajerus View Post
    Indoor fan running.
    Nov 2000
    Eastern PA
    First off, define "pumpdown". If you are referring to using the compressor to bring most of the refrigerant into the condenser/heat pump, then fast is not always a good thing, especially if you have a scroll compressor.
    Do not allow the system to pump down to less then 20% if you don't want to take a chance on damaging the compressor or even having the fusetite seal on the compressor blow out.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
