Results 14 to 16 of 16
    Lancaster PA
    it should be just after the traps. that can be a hazzard if its not high enough. If the drain cloggs after it, it could allow water to over flow and damage your ceiling.
    Jun 2008
    west point, ga.
    If there is a tee before the trap it is to clean and treat the trap and it does have to have a cap on it.
    The tee after the trap is a breather and no it does not have to be caped but as stated it has to have a pipe coming off the top higher than the drain itself.
    Make sure to keep drains treated once a month.
    Dothan, Alabama
    I would check to see if the unit is double trapped causing vapor lock. No such thing as to much condensation . That just proves your evaporator is removing heat and humidity. You just need it to flow out.
