Results 1 to 13 of 14
    Jun 2008
    DFW area
    It's all about proper Installation !
    Long time reading here (learning) mostly - question time now.
    A "consistent" theme here, without regard to system manfufacturer, or even sizing to a degree is It's all about a proper installation. With literally thousands of contractors in any major large metropolitan area, they all pitch the same line.
    The question is, how is one to know what is a "good install" as opposed to an "ok" or "really crappy" install? After 11 years in our house with the existing A/C (2.5 ton Carrier) during summers I've never been to get the house comfortable....the A/C ran continuously from 10 AM till 2 AM before it clicked off. And, this was for the downstairs unit! Not even discussing the upstairs yet! You can only imagine the utility bills.
    So, having had 4 bids out of hundreds in my area, one actually did a computer version of the Manual J Load Calculation and it came up to minimum 3.5 ton for the downstairs (2900 sq ft / 1700 down- 1200 up)
    After quickly learning the 1/2 ton units dont come in newer technology dual speed compressor / fans, went with a 4 ton Amana ASX16 seer entire sytem. Amazing now to be able to hold 68 degrees even on the hottest days 95+. System cycles high for a couple of minutes then to low speed for 15 min or so then as needed back to high speed again or off late in the day and at night.
    Sorry...back to the question. Anyway...... The contractor I choose came in with the LOWEST bid, and I offered the other 3 bidders a chance to meet or beat their price - matching component to component / apples to apples comparisons- NONE of them ever called back again!!!
    So.. they came out 2 days later and installed a complete new system (incl gas furnace). BBB showed in biz 22 years, 3 complaints, all resolved in last 36 months, all the certifications and members of various HVAC groups, etc, etc. - They were not some fly-by-night operation!.
    As a DIY sort of guy, I feel fairly knowledged in a lot of things, especially common sense applictions. The guys did what I consider to be a nice install. Added another supply vent and a 12 x 12 return air in another location to improve circulation and add more return capacity (CFM's).
    OK.. SO.. How do I actually KNOW, what is a good install and what isn't?
    leland nc
    it is the way you want it
    it works the way you were told it would
    you are happy with the work and the additudes of the porple there and the quality or thier all arround ethics
    these are what count IMO
    Jul 2000
    Northern Wisconsin
    You got a good installation if you can't find a thing about it that makes you question it's quality. Every room and space that is conditioned stays at an even temperature and can be heated or cooled as you'd like it. You installed equipment matches the quote as far as model numbers and size. When they were done wherever they worked was as clean or cleaner than when they got there. Everything about the system, it's operation and maintenance was described to you in detail. The start up was documented on each part of the system. They took down readings and measurements for future reference during routine maintanance to insure everything is within manufactures specs.
    California
    Good installs meet current code and comply with manufacturer recommendations and guidelines. They have correct clearances and observe best construction installation practices, incorporating trade knowledge to ensure safe, efficient operation and provide the full expected lifespan of service to new owner.
    A great install reflects signature quality work, pride in tradecraft and a sense of 'we touched it - we own it'.
    DC Metro Area (MD)
    Post some pictures and they'll let you know...
    Pictures and insist on a static pressure test.
    Doesn't sound like enough duct work was added for what sounds like an additional ton of A/C.
    Sounds like You did your "home work" and Shopped around got what you payed for (and did not skimp on Eq,) That help allot - also you offered others a chance to match or beat your lowest bid!
    Sounds like it's meeting your expectations (cold and better air flow though-out house) and from your point of view - they did a good job
    I would offer them to come check system out after 6 mo and 1 yr - to check performance! (even if you pay service fee - maybe they will give you a discount because your a Happy customer) so while its under warranty! may catch anything while it is.
    To me sounds good - especially hearing so many "NIGHTMARE" Stories on here!
    Grundy Co. IL
    Don't see too many Amanas, just tell me the acess panel on the condensor is not on the back, against the house.
    May 2008
    Sounds like you answered your own question. The installation looks good and you are happy with the results.
