+ Reply to Thread
Results 1 to 2 of 2
Thread: Cpr valve pressures equalize?
    Sep 2014
    My question is about CPR valves and pressures equalizing. I was working on an ice cream coffin case freezer. Hussman m#gim-6 s#97b01007-958. Semi -hermetic with cpr valve. Takes 404a, uses a txv and receiver. The unit was iced up, thawed out evap. Unit low on gas, i fixed leak and it working again. Now after the unit was off for an hour or so and i put my guages on at the compressor. And my low side pressure was around 60 with the compressor off. I turned unit on while checking amp draw to check cpr valve. Amp draw was good, low side pressure dropped to 15 while on inlet of cpr was 50. The pressures on each side of the cpr valve were equalized before starting unit back up. I asked 2 fellow techs is it normal for the cpr valve to equalize on both sides if unit was off for a while. One tech said no it shouldnt do that and the cpr valve is leaking by. The other tech said its normal for it to bleed by and equalize. My question is....should pressures equalize or not on each side of.cpr valve?
    Southold, NY
    CPR valves hold back the suction pressure while running not idle!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
