Results 1 to 2 of 2
Thread: New Heat Pump
    Apr 2006
    New Heat Pump
    Just had a new carrier infinity 4 ton 16seer heat pump installed. They just about have all the rooms balanced and with equal temp. My question is will the heat cylce be the same balance? Do you usually have to go back and adjust the ducts to balance the air conditon and heat?
    Likely depends on location,type construction and windows.
    Here in Florida ,usually not,if needed the customer can usually handle by partially closing grilles in the opposite season for the room that are too cool or warm.
    Each home is unique ,so the required air flow(cfms) to each room for heating or cooling can vary quite a bit.
