Results 14 to 26 of 30
    Jun 2008
    Quote Originally Posted by smokin68 View Post
    Smart. Get a tech to check it out. It can be anything from a compressor to a shorted wire. All you'll get here are guesses. Prepare for the worst, hope for the best.
    I guess that's what i'm gonna have to do considering home warranty won't fix it.
    Florida
    You have a home warranty and they won't fix it? What reason did they give you?
    Jun 2008
    They have given me all kinds of reasons as to why they can't fix it. The outside unit is a 3 ton unit and the inside is a 4 ton. The ac tech said they are not compatible.
    Lancaster PA
    Post the mod numbers of both units.
    Some one may be able to verify either way if that is a match.
    Some brands did use larger indoor units then outdoor units.
    that tech that said that could could very well be full #### a 4 ton drive furnace on low speed blower could be just right and the oversized coil should not be a problem . there is a possibility that it could be a properly matched system
    Jun 2008
    where do you find the mod numbers?
    Lancaster PA
    Depends a little on brand.
    OD unit, look near where the copper lines attach to it. Probably just above them.
    ID unit, look around where the lines attach also.
    If you also have a furnace, it should be inside the access panel.
    Jun 2008
    Thanks I'll go check it out.
    Jun 2008
    OK Found the numbers..
    OD Coleman cooler 10
    model number BRCQ048B
    Factory charge 5.13 oz
    ID Nordyne
    model number CIQA-036U-B
    charge 1 oz
    Think I found the problem.. They OD unit specifies a 40 amp breaker. the breaker that keeps flipping is a dual 30 amp breaker!
    Lancaster PA
    Good. Because that is a bad mismatch.
    you need a new matched system
    Jun 2008
    the units don't match?
    beenthere you type to fast for me to keep up
