Results 14 to 17 of 17
    Oct 2006
    Springfield, Clarksville. Tn
    Mastic Tape?
    I'm sure most of you are talking about Mastic Tape,...Very easy to work with and extreamly difficult to remove, an excellent product.
    Ken
    mastic tape?......mine comes in goop in a bucket.
    Quote Originally Posted by BigJon3475 View Post
    Mastic tape, aka rollmastic, aka butyl tape.
    Basically it is foil tape with a thick butyl rubber adhesive. Fairly expensive.
    I use it for sealing equipment connections, like furnace to coil, and for sealing plenum and transition connections to the unit. Its fast, won't fall off ever, and when I wrap the plenum/transitions with duct wrap, there isn't an issue with taping the vapor barrier to the unit like there would be if we used brush on mastic.
    http://www.hardcast.com/PRODUCTS/pdf...181BFX_tds.pdf
    http://www.shurtape.com/Default.aspx...8&ProductID=98
    RSES Certificate Member
    RSES-SWRA President
    Thanks.
