Results 1 to 8 of 8
Thread: Y'all saved me money!
06-25-2008, 01:06 PM #1
- Jun 2008
- 63
Thanks. After receiving a large electric bill, I began researching ways to cut my ac bill. After searching this forum, I found my cycle time was way too long. So I reduced the SPAN mode on my TStat to the minimum. My daily usage dropped 10 kwh per day since with no change in comfort level. That would be $2 a day or $300 per cooling season. Free Money! I still can't get to the recommended 10min on/10 min off cycle, but am at 30min on/30 min off. Maybe need another TStat with shorter SPAN setting.
I think I'll go out and stimulate the economyhttp://www.hvac-talk.com/vbb/images/smilies/smile.gif
06-25-2008, 05:29 PM #2
Send poor Twilli a couple bucks
06-25-2008, 05:43 PM #3“I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
No Guns…No Freedom…Know Guns…Know Freedom.
06-25-2008, 07:44 PM #4
since we saved you money........
Aint it only fair that you give it to us
On second thought.....don't worry about it. We don't work for free. And this constitutes work. So the bill is in the mail.
$300 you say.....we may be able to swing that.
$300 a month should cover it nicely.
Thank you for shopping HVAC-Talk. Please come again
06-25-2008, 08:24 PM #5
You really need a meter-record, along with weather-condition-records on an A/C, to claim that a T-stat setting change, saved that much money.
Depending on the time of day & all other conditions, a 30min on 30min off cycle sounds okay. Again depending on conditions, the 30min OFF time, could be saying, that the heat gain is at a decent level.
Please, I advise you NOT to totally WASTE your money on another T-stat, send us that money instead.
Darrell
AOP Forum Rules:
Rules for Posting
Rules For Equipment Owners
Equipment Owners Find a Contractor HERE!
udarrell
06-25-2008, 09:11 PM #6
- Jun 2008
- 63
Yep, been checking each day all month with fairly constant weather in the mid 90's and 50% rh. The only time the usage has been this low was 2 cloudy days and then every day for the week after changing the setting. I'll keep recording daily readings, and if they go back up, I'll revise my claim.
Don't get too excited about the check. I have 5 grandkids waiting ahead of y'all! Just keep a warm heart from knowledge you are helping people and my enduring thanks.
07-10-2008, 01:21 PM #7
- Jun 2008
- 63
I'm back with the June results = 210 kwh less than May. Not quite 10 per day, but June is a hotter month.
The point of this exercise is that homeowners should try various settings, even when they may not make sense, to find what's most efficient for their system without sacrificing comfort.
Great forum. Good info. Thanks for sharing.
07-10-2008, 01:35 PM #8
Now if your Tstat is programmable and reconfigurable to intelligent recovery or not, remove it from intelligent recovery and you will save more. Intelligent recovery basically causes the A/C to start eary in an attempt to achieve the occupied set point at the occupied start time.
No intelligent recovery has the Tstat start at the occupied time so it ends up acting more like a time clock. You'll suffer a little on comfort but savings are savings."The American Republic will endure until the day Congress discovers it can bribe the public with the public's own money.
- Alexis de Toqueville, 1835
