Results 1 to 9 of 9
06-25-2008, 11:50 AM #1
- Oct 2005
- 45
Are these a/c comparable or am I getting jacked around - AGAIN!
Hello,
I am having a a/c replaced after 3 summer of inadequate cooling. They have replaced the A coil several times. However, now they have the go ahead from Bryant to replace the condenser and the a coil with a new 3 ton unit. Old one was 2.5 ton.
However, they replaced it with what seems to be a lower quality unit.
I originally purchased a bryant heat pump - 650anx030 and they are replacing it with a model 224ana036
I know the one I purchased in 2005 was a Preferred series and this is their lower tier legacy line. Is this something I need to address?
06-25-2008, 03:16 PM #2
you are actually getting a 14 seer instead of a 13 seer unit, i would think you are better off
06-25-2008, 03:28 PM #3
- Oct 2005
- 45
But it is the lower line. Is the difference between the two all cosmetic?
06-25-2008, 04:51 PM #4
That and features. Is there a diff in warranties?
No reserve. No retreat. No regrets.
For those who have fought for it, freedom has a sweetness the protected will never know.
http://www.airwarvietnam.com/16thSOSGunners2.jpg
Proud member of KA Club
06-25-2008, 05:40 PM #5
Moved into residential.
06-25-2008, 05:51 PM #6
Personally I'd say the 224 is a nice step up from the 650.
06-26-2008, 11:07 AM #7
- Oct 2005
- 45
Thanks,
Thats what i figured - i just wanted to make sure. Unfortunately I have lost faith in being able to trust this HVAC company and I will be glad when I have a working system and we can both move on.
Hopefully 3 ton will cool my house since 2.5 ton never did -- even with a 3 ton coil.
It got it down to 75 degrees by this morning -- but....its only 72degrees outside
It has been a very long time waiting!
06-26-2008, 12:21 PM #8
- Jul 2001
- 3,112
Rethink you rattitude of the company. Takes a lot to get a manufacturer to approve the replacement of a complete system. Give them credit for sticking with you. Not an equipment problem, an installation problem. Who did the load calc and determined 2.5 ton would work?
06-28-2008, 02:10 AM #9
- Oct 2005
- 45
No load calc was ever done. The went off what i told them the sq. footage of the house was.
It took a lot of cajoling for me to get them and its only becuase they are the "Authourized Bryant Dealer" for our area and give a comfort garuantee that the system would cool the house to 75 degrees - and it simply wouldn't.
My old threads doa pretty good job of outlining past problems I have had since it was put in summer of 05.
I agree though-- I do give them credit for not giving up on me -- this stopped beign a money making venture for anyone involved about the time the third a coil was replaced.
