Results 1 to 9 of 9
    Oct 2005
    Are these a/c comparable or am I getting jacked around - AGAIN!
    Hello,
    I am having a a/c replaced after 3 summer of inadequate cooling. They have replaced the A coil several times. However, now they have the go ahead from Bryant to replace the condenser and the a coil with a new 3 ton unit. Old one was 2.5 ton.
    However, they replaced it with what seems to be a lower quality unit.
    I originally purchased a bryant heat pump - 650anx030 and they are replacing it with a model 224ana036
    I know the one I purchased in 2005 was a Preferred series and this is their lower tier legacy line. Is this something I need to address?
    Oct 2006
    Baltimore
    you are actually getting a 14 seer instead of a 13 seer unit, i would think you are better off
    Oct 2005
    But it is the lower line. Is the difference between the two all cosmetic?
    SC
    That and features. Is there a diff in warranties?
    No reserve. No retreat. No regrets.
    For those who have fought for it, freedom has a sweetness the protected will never know.
    http://www.airwarvietnam.com/16thSOSGunners2.jpg
    Proud member of KA Club
    Howell, Michigan
    Moved into residential.
    Personally I'd say the 224 is a nice step up from the 650.
