Results 1 to 10 of 10
    Nov 2007
    Rheem mod media filter question
    The filter that is currently in my furnace is 16x25x5, and I was wondering if it would be ok to use a 16x25x4 instead.
    I am having a hard time finding a 16x25x5 locally. Lowes and Home Depot sell the 4" filters all day long... which would make it much more convenient to buy a filter when I need it.
    Or.. for future filter needs, if anyone would be kind enough to provide a link to a reputable online store... please do.
    Thanks,
    Mark
    Toledo, Ohio, United States
    Twilli gots 16x25x5, but you could use 4 in
    You can get them from your installing contractor.
    DC Metro Area (MD)
    I've used http://www.ushomefilter.com/ before with success. Can you make the 4" fit securely? What kind of filter cabinet do you have? I'm sure someone else can help you out with this, but the online store listed above could work as well...
    Jun 2008
    Quote Originally Posted by audio guy View Post
    Thanks,
    Mark
    What I did was used a good 4", and added one of those real thin blue filters on top. It doesn't restrict much and I changed it out once a month. It really catches the big stuff(cat hair) and saves the 4" filter, which I changed 2 times or les a year.
    Clay
    Cedar Grove, Wi-Sheboygan
    That's exactly what I was gonna say !!! simple math 4+1=5
    Nov 2007
    Thanks for everyones help, much appreciated!
    Mark
    May 2005
    Lake County,Illinois
    Quote Originally Posted by DanW13 View Post
    That is very good thinking McGyver, I had a customer once who called for a no heat and guess what i found.......he just replaced his filter(s), High limit stuck, he had a 16x25x4 cabinet but said he wanted the most amount of filtering possible and that it was cheaper for him to go with the 3M brand purple package pleated filters, wife almost killed him when i told them it was the smart thinking that was causing the problem!
    Jun 2008
    Quote Originally Posted by castillo7411 View Post
    Explain how the two are related? the thin cheap blue filter adds very little to the air restriction in front of the 4" filter. Maybe none over the 5" that was supposed to be there?
    Clay
    May 2005
    Quote Originally Posted by frijoli View Post
    Clay
    Sorry, I think the 4" with the 1" fiber type is a very good Idea, and I was simply pointing out what NOT to do to get the 5" or 4" width. Sorry about the confusion!
