Results 14 to 26 of 50
    Jun 2008
    Bartlett, TN
    I'm thankful for any and all info here.
    This is just the best ever to have all of this knowledge at your fingertips.
    media,pa
    it sounds like you are still undercharged,but you need to check your sh or sc.
    Nov 2000
    Eastern PA
    Quote Originally Posted by kg321 View Post
    Goodman, 4-ton- 3 yrs old.
    I've always relied more on the pressures than reading SC SH.
    Guess I need to make SC SH part of routine checks.
    Pressures alone tells us absolutely nothing except that there is something in the system or not.
    Government is a disease...
    Ecclesiastes 10:2 NIV
    Jun 2008
    Bartlett, TN
    At 65 on low side, even if still a little undercharged, would'nt suction line be sweating, cool, or something. If I add more gas, the head pressure will continue to go up.
    Nov 2000
    Eastern PA
    You need to get accurate temperatures of refrigerant tubing before anyone can tell anything. This is why there are T/P (Temperature/Pressure) charts. One without the other is meaningless.
    Toledo, Ohio
    Twilli says 3 more post and you can apply for pro membership
    Jun 2008
    Bartlett, TN
    I like the way Twilli thinks.....
    Houston,Tx.
    Twilli Thinks?
    “I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
    The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
    No Guns…No Freedom…Know Guns…Know Freedom.
    Apr 2008
    The only reason i look at pressures is to know saturation temps of coils.Sh and Sc very important!
    Jun 2008
    Superheat is a pain
    I understand this guy falling back on pressure. I am new contractor, but I just find SuperHeat is difficult for me to measure. I get the target and actual, but I always feel uncomfortable that i am not doing it right, I use a digital therm for my wetbulb (I hate thought of using sling) and i use a digital therm with a probe for my suction line. Drives me nuts. I never feel the numbers are right. Do i have to wrap the suction line with a towel to get a good reading... Any advice on an easier way would be appreciated. Oh yeah, any comments on just using some of those fancy electric Superheat readers out there?
    Lancaster PA
    A good clamp probe will get you a good reading from your line set. No need to wrap it.
    Toledo, Ohio
    Twilli says buy a set of digital guages
    Jun 2008
    Twilli do you mean digital gauges for my superheat or just my pressure. So you guys think digital superheat readers are better than old fashioned methods. Someone else chime in I need another opinion other than twilli one liners. Which vendor has best set of digital gauges. My supplier does not stock them, they have to special order.
