Results 1 to 6 of 6
    American Standard Condensing Unit
    Found a used 2 Ton Condensing Unit
    For Sale.....the lady selling it claims ..it's only 5 yrs...old
    she doesn't...know the s.e.e.r rating
    any one know what this condenser is
    American Standard
    M # 7 a0024a100a2
    s # 2073T3R4f
    DC Metro Area (MD)
    10 SEER. See my attachment for the literature on it.
    Be careful with used units...
    MN
    I would not recommend buying a used unit from a homeowner, as you will have no body to stand behind any breakdowns, or to verify it worked on removal, we occasionally have a used unit to sell if someone adds on and has to upsize, or switched to Heat Pump. But we know it works, and can give some sort of guarantee. HO can't do that for you.
    You can't fix stupid
    Cincinnati, Ohio
    Unit was shipped from factory on 3/4/2002.
    Unit came with standard 5 year parts warranty and 10 years on compressor and coil
    Jun 2008
    va
    The warranty is probably non'transferable since it has been relocated from another residense. Hopefully whoever removed it pumped it down and closed the service valves. If the tubeing is hacksawed off and/or the valves are still open, I'd bail on it. I sell used units once in a while, but at least I'll pump it down and close the valves for some protection.
    Ohio
    Used equipment is like polishing a turd.....you can spend all day shining that thing up...bottom line is.....it's still a turd
    I need a new signature.....
