Thread: york ahu
    Dec 2006
    philadelphia pa
    york ahu
    Does anyone know where I can download some info. for a York AHU model-F4FP042H06T2AA serial-AOG6596756 ie. the logic board. the fan runs all the time,even when I lift the wire off G term.
    carthage ms
    check the heat strip limit switch, i have had several that are bad and the fan runs all the time on that unit if that switch is open
    The 2008 NATE TOP TECH!!!!!
    Jun 2001
    Louisville, KY
    Jun 2006
    Southeastern Connecticut
    If there are no heaters installed you need to have the no heat plug installed on the board (white plug with one jumper wire in it).
