Results 1 to 8 of 8
    April aire humidifier
    putting a cased coil on top of the trane furnace...
    foe AC
    ...existing humidifier will need to be moved....no room on supply trunk......is it possible to place the humidifier on the return plenum....close to the furnace ?
    Suppy NC
    yes in most cases
    Jun 2008
    Wisconsin, USA
    what model humidifier do you have?
    Wyoming, missing NE Wisconsin
    Your April Aire will be just fine.
    What filter?
    April aire
    Model # 550
    I had it tied into the supply plenum....
    but now ....witht he cased coil.....no room.....So it will be placed on the Return plenum....
    Should I get the same results ?
    This April aire .....also has a 6" takeoff ...on the side....that would normally go to the return......
    I........... will probably have to cap that off......
    Jun 2008
    Wisconsin, USA
    No... you don't want to cap it off, you have to pull heated air through the water panel.
    Here is a link to all of Aprilaire's Manuals:
    http://www.aprilairecontractor.com/p...humidifiers#20
    Humidifier...duct to supply
    O.K.
    I took a look at the manuals....
    .......... IF...I attach the Aprilaire..mod #550
    to the return plenu.....then off of the
    6" collar...
    take a 6" 90 26 g.
    bring a short piece of flex to the supply plenum....will this work
    The manuals ...did not really get into installation Options...
    Jun 2008
    Wisconsin, USA
    Yeah that should work fine... all you have to do is pass air off the plenum through the water panel in order to make it work. You should also put a damper in your flex line off the plenum so you can close it off in the summertime and not recirculate your a/c back into the return drop.
Comfortech365 Virtual Event
