Results 14 to 26 of 34
    Lancaster PA
    Thanks John.
    My eyes must be bad. Theres over 240 views of this thread.
    But still I don't see anyone else explaining or giving an example to the OPs question.
    But I'm VILE. ROFLMAO.
    Houston, Texas
    Ok everybody join hands because we are gonna sing Kumbah Ya and feel some love in here
    Lancaster PA
    You been sipping some of your name. )
    i think that zeetammie should have left her post count at 0
    Houston, Texas
    Nope i quit and got a dollar raise
    I didnt read anything but good info from your posts
    Lancaster PA
    LOL...
    It was a waste of a first post.
    Lancaster PA
    Quote Originally Posted by southerncomfort View Post
    Thank you.
    I didn't quit, I just don't drink like I use to.
    One of the nice ones will be along sometime.
    My back pain has me in a not nice state.
    I'm just waiting for someone to happen along and argue that the larger coil increases humidity removal due to the larger surface area.....so I can rip out their spleen.
    Houston, Texas
    Smile
    I went on a call the other day and the complaint was the upstairs system was not cooling as well as the old unit did.
    It was a new install and i could not get more than 12 degrees split
    I checked and re-checked everything and even charged the system with new refrigerant 410A, I still couldnt get more than a 12 degree split
    I got tired of the homeowner looking over my shoulder so i gave him a bucket of pukkie and made him seal his return chase
    TXV was good, static pressure was fine on both ends
    This was a Amana ASX14O301AB condensor with the factory matched 3 ton evap coil
    The coil was huge and I ended up replacing the condensor with a ASX140361AB and BAM welcomed a 18 degree split
    The homeowner had puckkie all over his ass when he emerged from his return chase...
    I was so happy i popped a wheelie on the way home
    Lancaster PA
    That myth has been around for longer then I can remember.
    Of course, these days my memory isn't as long as it used to be.
    Lancaster PA
    Maybe the salesman just got the mod numbers off the old indoor coil, and thought the old system was only a 2.5 ton be cause its common to have that 1/2 diff rating between indoor and outdoor.
    Jun 2008
    South,Tx
    the distributor sells 1/2 ton bigger for effiecency ?
    this is just one of those ideas that creep into the counter people with out any knowledge of what they need to match it !
    Matt 7:12 The Golden Rule
    "Do for others what you would like them to do for you. This summary of all is taught in the law and the prophets.
    Lancaster PA
    In many cases it does increase efficiency.
    The question though. Is does the increase hurt latent capacity too much.
