    I don't know
    Energy efficiency of waterheater
    Ruud
    Model: RG50-50CM
    Serial: 0791J97815
    Capacity: 50 US Gallons
    50,000 BTU
    Recovery - 42 (?)
    Installed - 1991
    What's the energy factor of this old gas waterheater? Were waterheaters even rated in the early 90s?
    I'm curious to know if today's natural draft models are significantly more efficient than what I have. I looked at the specs of new models and they're all piss poor - ranging from 0.58 to 0.60.
    I've discovered a natural law - everything gets progressively worse. Things only break down and become depleted. Life isn't worth living and everything is going to hell.
    Death is the messiah. Everything else is irrelevant and arbitrary.
    south louisiana
    prolly about a .56 based on the age.
    Whirlpool has a .65 ef gas water heater. Lowes carries it.
    Good water heater.
    Tankless gas units ( I like to put them on exterior wall and not have to buy the venting and cut a hole in the roof) achieve up to .82 energy factor, and it seems like I have seen a couple that were .85
    best of luck.
    Sep 2006
    Here is a site with lots of ratings and other good info:
    http://www.gamanet.org/gama/inforeso...ct+Directories
    south louisiana
    thanks mchild...I forgot to include the gamma site.
    I don't know
    Thanks - I think GAMA only lists current products online.
