Results 1 to 10 of 10
    Nov 2005
    Any energy savings in shading outside compressor unit?
    I have a split system heat pump & AC, with the compressor unit outside on the south side of the house. Would there be any energy savings by shading the outside unit with shrubs?
    Jun 2008
    Wisconsin, USA
    Absolutely... But don't plant anything that will block the airflow to the condensing unit, and remember to give the service technician at least 2 feet on each side of the machine to service it and clean the condensing coil.
    The only real energy savings would be if the air temperature in the area gets higher than the normal ambient temperature, and you can shade the entire area without restricting air movement at all.
    Just shading the unit won't help, and most attempts to do so actually end up harming efficiency.
    RSES Certificate Member
    RSES-SWRA President
    May 2008
    North Texas
    HTML Code:
    http://www.fsec.ucf.edu/en/publications/html/FSEC-PF-302-96/index.htm
    Jun 2008
    Wisconsin, USA
    Nice one sparks
    May 2008
    North Texas
    De nada. Enjoy.
    Jun 2007
    The Twilight Zone
    Having just read the link that was posted by "Sparksandfan", you are indeed correct.
    Jun 2008
    Wisconsin, USA
    The article also discusses the extra heat load from the sun beating on the condensing coil.
    The answer is YES, it is beneficial to shade the condensing unit from the sun.
    Jun 2007
    The Twilight Zone
    From the article posted:
    "Our experience also illustrates the hazards of localized condenser shading, underscored by the poor results achieved in these experiments relative to the careful planning involved. Planting trees and shrubs close by a condenser may actually reduce system efficiency due to impedance of effective air movement.
    We conclude that any savings produced by localized AC condenser shading are quite modest (<3&#37 and that the risk of interrupting air flow to the condenser may outweigh shading considerations. The preferred strategy may be a long-term one: locating AC condensers in an unobstructed location on the shaded north side of buildings and depending on extensive site and neighborhood-level landscaping to lower localized air temperatures."
    I hear what you're saying, Air-Doctor, but I would be very careful trying to shade an existing condenser. Shading back-fired on Site #2 in the article.
    Take care.
    Jun 2008
    Wisconsin, USA
    Well yeah... if you fail to plan, then you plan to fail.
    In my 1st reply to this question I said:
    "Absolutely... But don't plant anything that will block the airflow to the condensing unit, and remember to give the service technician at least 2 feet on each side of the machine to service it and clean the condensing coil."
