Results 1 to 8 of 8
    Dec 2006
    honeywell stats gone rogue
    anyone ever heard of these kinds of problems with these stats??????
    2 stats, 2 problems i havent seen or heard of before.
    1st one was a honeywell t-7300. After the spring startup was done, there were two problems with units being locked out in the morning and not working. After troubleshooting a machine in one of my buildings.I suspected that the stat would randomly come on in the middle of the night and lock one of the units off on high pressure (towers and pumps are shut down). The occupied/unoccupied times and temperatures were correct for each day. Customer didnt want to buy a new stat so i installed one of those mechanical paragon time clocks to break the Y wire when the pumps and tower are off at night. It solved the problem.
    second stat was a honeywell t-7350. same deal. came in and unit locked out every morning. ok terrific. Problem with this was that when the unit switched to unoccupied, it copied the occupied temp setting of 73 degrees (unoccupied was set to 99 degrees). At a glance all the programming for dates times and temps were correct to keep the unit on during the day and off at night when the towers are down. replaced the stat, programmed to same times, and waaaallllaaaaa, works great
    also, im not crazy about needing a pda to set the heat pump settings for the o/b terminals on this either....
    Nov 2000
    Eastern PA
    Spelling errors are pretty funny at times. I was wondering why a t-stats rosy color would offend anyone.
    Need to watch more X-Men; Rogue would not be pleased with being called rouge.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Pacific Time Zone
    Did you check both occupied and unoccupied programs? As in there are more than one on both models.
    Illinois
    Quote Originally Posted by RoBoTeq View Post
    Just for you Robo...I fixed it (And I thought the same thing
    Dec 2006
    Quote Originally Posted by crab master View Post
    yes occupied 1 and 2 and unoccupied 1 and 2. i checked that they were only programmed with occupied 1 and unoccupied 1.
    And senior tech thanks for the edit, its one thing to misspell in a post, but to do it in the title, ouch
    sometimes i amaze myself, for the better and for the worse
    Pacific Time Zone
    I've always put unoccupied 2 to 12AM, and left occupied 2 blank. I don't know if it is necessary, but just something I've always done. Actually I recall one of the techs I trained under taught me to do that.
    Pacific Time Zone
    Also are you sure there is no heat source near the stat that may be causing the issue - sun shinning on the stat in the early/late hours, water cooler, coffee maker, monitor/other under/near the stat?
    Dec 2006
    nope nothing like that, small 3 room office the stat is mounted on wall in middle of room, there is nothing that would cause any temp fluctuations. i did have my thermometer turned on at the time when i was looking at the stat, and when i reached to turn it off, it was measuring the same temp as the stat was.
