View Poll Results: Do you use a micron guage when pulling a vacuum?
Voters
128. You may not vote on this poll
  • Yes
    116 90.63%
  • Nope, we don't own one.
    12 9.38%
Page 4 of 18 FirstFirst 123456789101114 ... LastLast
Results 40 to 52 of 224
  1. #40
    NW burbs of Detroit
    I don't need a micron gauge I have a pressure switch on my pump that shuts my pump down at a 500 microns.
    That must be one heck of a transducer you got sensing the micron level.
  2. #41
    Houston,Tx.
    Quote Originally Posted by hvaclover View Post
    That must be one heck of a tranducer you got sensing the micron level.
    You bet it's NATE approved Tranducer and I also did a Manual D on it so I know it's right.
  3. #42
    Baltimore area
    Posative press won't suck in moisture. I'll stick with that. I have yet to find a micron guage that is accurate or does not require a ton of maintenence.
    Then you need to get yourself one of these http://www.testequipmentdepot.com/ro...uum/14010a.htm !!
  4. #43
    NW burbs of Detroit
    Quote Originally Posted by refrtech View Post
    Efhardystou.
    I had the anolog version of that Robinaire when I did refer. Never used on an A/C cause it was considered over kill(30 years ago. So don't beat me up because attitudes were different then).
    Thing had a monstrous vacuum tube thermistor sensor and a big scale and meter movement.
    Thanks.
  5. #44
    Jun 2008
    to those of you who dont use them........your not doing a very good job! 30" of HG is a long way from 500 microns, this you would never know by just using your gauges. under 500 microns is where you want to be to have all the moisture out of the system. The old 1000 microns is good enough just wont fly anymore.
  6. #45
    IMHO only a HACK would pull a vaccum on a system w/out checking the micron level .
    Again just my opinion
    +1 for that opinion.
    If you don't/won't use a micron gauge, do everyone a favor and find a new trade.
  7. #46
    Jun 2007
    Greenville,North Carolina
    Which is twice a year weather the system needs a vacuum or not.
    ROFL
    LOL,thats funny even if beenthere said it....
    Look to the past to learn;look forward to live.
    Coach Dean E. Smith
  8. #47
    Quote Originally Posted by DPSwitch View Post
    i use it every time....... why?
    Cause is looks cool and the chicks dig it.
    I guess when you measure "it" in microns it sound a lot bigger!!
    Expect nothing, yet expect the unexpected.
    Press on Regardless, Endeavor to Persevere.
  9. #48
    Jan 2005
    i use it everytime the system is opened and i EVEN change the oil in my pump
  10. #49
    Quote Originally Posted by fitterchick View Post
    Yea, 30"hg is a lot lower then 500 microns.
  11. #50
    Jun 2008
    Wisconsin, USA
    ...not to mention 30"hg of vacuum is an impossibility. If a "technician" trusts the needle on his/her compound guages to be zeroed perfectly and totally accurate then they are not a technician.
  12. #51
    Quote Originally Posted by air-doctor View Post
    Or just mislead by the people that were training them.
    30"hg, would be a perfect vacuum. And 500 microns is a long way from a perfect vacuum.
  13. #52
    Jun 2008
    Wisconsin, USA
    True.
