View Poll Results: Do you use a micron guage when pulling a vacuum?
Voters
128. You may not vote on this poll
  • Yes
    116 90.63%
  • Nope, we don't own one.
    12 9.38%
Page 3 of 18 FirstFirst 1234567891013 ... LastLast
Results 27 to 39 of 224
  1. #27
    Jul 2001
    VA
    Quote Originally Posted by I_bend_metal View Post
    I have the CPS also...I love mine...works great
    I like mine too.........just haven't compared it's readings to my YJ.
    ___________________________________________
  2. #28
    Ohio
    Let me know how that comes out....I have had my eye on the YJ too! Mine put the wood to a fieldpeice the other day!
    I need a new signature.....
  3. #29
    NW burbs of Detroit
    If you're not using one....you have no business being in the field.
    Your shameless//////
  4. #30
    Dec 2006
    Northern VA
    Maybe I just got a bad one. It seems to eat batteries.
  5. #31
    Ohio
    Quote Originally Posted by hvaclover View Post
    I resemble that remark
  6. #32
    Ohio
    Quote Originally Posted by EverettsHVAC View Post
    Could be....I have used mine on about 15 vacs in the last 6 weeks....still on the same battery although I did get the low battery warning yesterday morning. I will change it on Monday. That doesn't seem too bad for a 9 volt
  7. #33
    Baltimore area
    IMHO only a HACK would pull a vaccum on a system w/out checking the micron level . That is truely the only way to be 100% sure that you have zero leaks and that the system is contaminent free .
    Again just my opinion
  8. #34
    NW burbs of Detroit
    Quote Originally Posted by refrtech View Post
    Posative press. I like it better.
  9. #35
    Jun 2001
    Louisville, KY
    If you work for me and don't use your micron gauge, you'll be finding a new employer.
    Perhaps you should have read the instructions before calling.
  10. #36
    Baltimore area
    NOPE !! Positive pressure can and WILL lie to you , a standing micron reading of 500 or less WILL NOT lie to you !!! There is no arguing with that !!!! I have seen it more than once . Oh and for all of you that do not use a micron gauge , when your gauge on your manifold gets to 30"hg your actual micron level can be 5,000+ !!!
  11. #37
    Jan 2002
    Ft.Worth,Tx
    I 'm the only one at the company , that has one.That's why I take longer on repairs and find more tubes not metering or txv failures, due to no vacuum or not long enough vacuums. Nitrogen is used allot but, when you dry a system you have to remove non-condensibles .
  12. #38
    NW burbs of Detroit
    Posative press won't suck in moisture. I'll stick with that. I have yet to find a micron guage that is accurate or does not require a ton of maintenence.
  13. #39
    Houston,Tx.
    I don't need a micron gauge I have a pressure switch on my pump that shuts my pump down at a 500 microns.
