Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 40
  1. #27
    Apr 2008
    Quote Originally Posted by tinknocker service tech View Post
    personaly i think the wall of pride is in order for this install
    some persanal preferances i would like to see but that should not take away the craftmanship and care this guy seems to have put into this job
    you made a good choice and your installer shows he cares and has class
    JMHO
    My install is "A" and I told the installer that his install was going to be a available for viewing on hvac-talk, and I think he took some extra care. I will forward him this link. They spent 2 days on the install and then their foreman came by for another hour or two a week later to confirm that I was happy with everything and answer questions on the furnace and thermostat. Excellent service! They did mention to me how to take care of the condenser and that I could take the top off/showing how i could hose it down from the inside.
    So far I am very pleased with the air conditioner (obviously haven't used the furnace).The thing that struck me between the 2 installs is how they dealt with the condensate coming out of the furnace differently. My guy "furnace A" used a much more complicated pipe arrangement, while "B" is very simple. My installer says he installed totally to Rheem specifications, so that would be mean B install is not to spec. B has a air conditioner, as well although not a Rheem.
  2. #28
    NW burbs of Detroit
    Quote Originally Posted by yazza View Post
    Check the inside of the skins in a year and than make up your mind about where debris have a place to be flushed out.
  3. #29
    Is that for the "A" jpg or "B" jpg?
    Also what do you think about the different approaches on the exterior of the houses?
    B looks worse due to the filter ,but A is about the same ,but cant tell if that is a filter exterior to the furnace or not.
    So either one we'd suspect high static.
  4. #30
    Jul 2001
    Are those furnaces sitting directly on the concrete? Should have installed some pads.
  5. #31
    Jan 2003
    Elkhart Indiana
    Blind
    I don't see return air restriction.
  6. #32
    Quote Originally Posted by achtgman View Post
    The type elbows used are more restrictive than what could have been used .In be there will be a lot of turbulence entering the filter ,which will increase the PD thru the filter.
    The filter could have been installed horizontially in the drop,with a proper transition to and from its size .
    Typically the filter shown is being addd to a duct system that likely wasn't designed for the PD ,so not minimizing the PD is usually a bad idea.
  7. #33
    I didn't look, but I think that ell is something like 65 foot of E.L.
  8. #34
    Quote Originally Posted by mayguy View Post
    The exhaust pipes, I'm not a fan of that two pipes with no elbow of some type..
    Why is the other one going to Mars???
    It is a new code, many are un-aware of, All 90% pvc flues must terminate within 18'' of mars.
  9. #35
    leland nc
    Quote Originally Posted by aintitfun View Post
    i heard it was an agreement with the Marsians because they need the warn humid air for their dry skin
  10. #36
    NW burbs of Detroit
    Tinknocker please. Some of us are HUGE si fi fans. It's Martian not Marstians.
  11. #37
    Florida
    That condenser just won't get washed as good as it should......otherwise install(s) look good. Everyone will find something they'd do different, someone will say the color doesn't match the house.
  12. #38
    NW burbs of Detroit
    Quote Originally Posted by smokin68 View Post
    Yeah but this poor HO thinks hes gonna be free and clear by just rinsing it from inside the condenser fan opening. And thw way it's installed (no offense to the installer) there is going to heavier than normal build up
    with no place for the debris to go.
  13. #39
    leland nc
    Quote Originally Posted by hvaclover View Post
    watching sci-fi right now
    sorry spell check didnt help either lol
