    Jun 2008
    Confused Need Opinions On Choice For Heat Pump System Replacement
    HELLO,BEEN READING SOME POSTS ON THIS SITE FOR SOME TIME AND HAVE
    FOUND USEFULL INFO FOR REPAIR AND UPKEEP OF MY HOME SYSTEMS.
    IT APPARENTLY HAS CAME TIME FOR A SYSTEM REPLACEMENT. CURRENT SYSTEM 22 YEAR OLD TRANE AIR HANDLER,MYLAR DUCTS THAT VAPOR BARRIER IS SPLITTING AND EXPOSING INS.AND INNER DUCT,OUTSIDE
    2 1/2 YEAR OLD 4 TON PAYNE 10 SEER (SUPPLIED BY HOME WARRANTY
    COMPANY) STILL COSTED ME WAY MORE THAN DEDUCTIBLE. GOT HOT LAST FEW WEEKS HERE DFW AREA AND COMPRESSOR QUIT COMING ON INTERMITTENTLY. SUSPECTED CAPACITOR AND CALLED FOR REPAIR
    SERVICE FROM A LOCAL COMPANY WAS TOLD YEP ! CAPS BAD ,AFTER REPLACED TOLD COMP.DRAWING HIGH AMPS (OLD INSIDES MAKING
    UNIT EXPIRE ) COULD PUT IN HARD START KIT ,AND WOULD/SHOULD TAKE CARE FOR NOW. (OK),WELL NEXT DAY SAME THING .
    GOT A QUOTE FROM SO CALLED REPUTIBLE DEALER FOR REPLACMENT OF
    SYSTEM
    AMANA
    R22 iM ASSUMING DISTINCTIONS (GOODMAN) WOULD
    NOT GIVE ME SPECIFIC MODEL JUST SAID O IT WILL BE
    14 15 SEER ????? PLAIN THERMOSTAT AND HIGH PRICE TAG
    I HAVE SETTLED ON A 15 SEER TAPPAN TECH 3 (TWO STAGE ,VARIABLE
    SPEED) W/TAPPAN COMFORT CONTROL FROM A RECOMMENDED INDEPENDENT. STILL FEEL A LITTLE UNEASY . WHAT DO YOU GUYS THINK ?
    UNEASY W/MY CHOICE
    ALSO HAD QUOTE ON SINGLE STAGE 14 SEER TRANE SYSTEM
    Two stage is always an improvement in comfort ,when instale correctly.
    We prefer the Carrier Infinity,but what you choose should serve you well.
    Jun 2008
    Post thanks
    thanks for your input dash.
    more details the big expert on comfort with original post like i said
    would not give specifics on model and did not mention the r-22 phase out
    and would not give specifics on models to be installed ,just said it would
    work at 14 15 seer with their enginered duct system and added insulation
    package . i found out on my own about the refrigerant change ,called sales
    rep and he said o the r401 systems are causing problems and not dependable,
    tappan and trane dealer said the r401 works great . what gives.needless to
    say i cancelled with the so called experts and getting the complete tech 3
    system for less than original quote and getting the extra insulation blown
    in from a local lumber co. for way less than the original expert.i think they are
    experts in taking peoples money. by the way installer says he figured i would
    want to keep the old unit,if it realy is the compressor would it be feasible to
    repair and keep on hand for our old house that we could not sell due to market and are having to rent. it is actually a 3 ton on a 1777 sq ft home
    ours id 4 ton on 1959 sq ft.
    Your rentals air handler is a 3 ton, and won't be able to move enough air for a 4 ton condenser.
    Most people/companies bashing R410A are just resistant to change, and will be left ouot in the cold after 2010.
    Jun 2008
    3 ton air handler
    i realize inside unit would have to upgraded,i am afraid 4 ton unit would be to
    much for size of house ,would run enough to dehumidify.with that in mind
    what should i do with old unit . my main question is feelings on the tappan system on main home is it as good of a unit as it looks on paper.the specs are nice and 10 year warranty (limited of course ) on parts and labor assistance on a fully matched system is a good choice.you guys should know
    the price range of systems.and i can get this full tappan system,new ductwork for somewhat less than the single stage trane.home had the matched trane system when i moved in ,i have had fits with it and apparently
    the previous owners did also the whole time they owned home (original owners) the crappy mylar ductwork didnt help im sure.some splitting was
    noted on purchase inspection but over three years ducts have deteriorated
    drastically
    Tappan is ok.
    You can use your old unit as a conversation piece.
    Or donate it to the local votech.
