Results 27 to 39 of 58
06-21-2008, 02:12 PM #27
- Jun 2008
- Ontario, Canada
- 18
I thank you for all your comments but its not buyer remorse. I expected a workmanlike job and I don't believe I got one. My concern about the refrigerant lines being heated by its location next to the duct is obviously not an issue but the following are:
The line may be exposed in the living room and the contract said it would be but the lines location prevents the vent cover from being replaced in the hole in the duct. So besides the lines there is a gaping hole in the duct and probably no room to build a box around them.
They have left the soft copper lines exposed in the furnace room so that anyone who has to work under this duct or get to the other side to access: the water lines to shut off or turn on the water to the humidifier, get to the items on the shelves on the right in the picture, access the hot water heater which is due to be replaced as it is 14 years old, or clean the air cleaner which is directly below the duct and refrigerant lines is likely to hit their head on the duct and refrigerant lines because the distance to the floor was less than 5 ft under the duct before they installed those refrigerant lines.
The electrical box outside that they installed for the service shutoff is not locked and the inner plate falls to the ground when the lid is lifted. There is no screw or lock of any kind to hold this inner plate in place. There is nothing to keep a child or my 3 year grandchild from touching the wire connections. The cover plate that is supposed to be over the wires falls to the ground when the lid is lifted. There is a swimming pool within 10 feet of this box as well and children swim in the pool.
Personally I think this is shoddy work and it was done with this lack of care because I am disabled and was not able to inspect their work or watch what they were doing and they knew it.
06-21-2008, 02:15 PM #28
- Jun 2008
- Ontario, Canada
- 18
06-21-2008, 02:30 PM #29
- Jun 2008
- Ontario, Canada
- 18
It was a case of not reading the proposal carefully enough. The salesman did tell me that he would run the lines exposed and I told him I didn't want that because it would lower the value of my house. He said he's done it a number of times without a problem so I finally said OK. I had no idea that it would end up looking the way it does because I expected them to attach it neatly like the original lines were. They ran straight across without the 'waves' and were installed by the same company as did this work.
I have hired very few people to do work on the house and when I hire someone with a good rep I expect a good job that is not going to cause problems in the future. Maybe when my husband was alive I would have been more forceful about what I wanted but I treat people who I hire as though they are professionals and will take care with their work. It's more my naivety than anything else.
I knew about the lines running exposed but did not expect them to cover the vent hole in the duct so the cover couldn't be replaced, nor did I expect them to run the lines the way they did in the furnace room due to the fact it creates an obstruction for maintenance of everything else in there. I look at the duct and think they could have run the lines over the duct rather than under it but I may be wrong. However, the plenum where the new A/C is above the duct in the picture.
Yes it was my fault for not pursuing the issue of what they were doing, but it is very difficult when I can't see what they are doing while they did it. I used to spot check any people doing work on the house but unfortunately unless they are working upstairs I no longer can.
Thanks for all the info and help I appreciate it.
06-21-2008, 02:32 PM #30
- Jun 2008
- Ontario, Canada
- 18
06-21-2008, 02:49 PM #31
- Jun 2008
- Ontario, Canada
- 18
Thanks everyone for your help and comments. I chose this company to do the work because they installed the original A/C for the previous owner and they also installed our furnace 10 years ago for us. Both were neat, clean jobs without any problems. I had no idea they would be less than careful and respectful of my property.
The electric box outside is a small thing but to me it says they were sloppy with the work they did not doing the finishing touches that others might have done. I am amazed that it passed inspection.
Maybe my attitude to treat people who are professionals with respect and expect them to treat the inside of a person's house as they would their own. That's what I expect from a professional. Maybe I should have had more quotes from different companies, but the temperature was in the 90's and my health suffers in the heat. I had past experience with this company and expected the same kind of treatment I received in the past when my husband was alive.
Thanks everyone for your comments, I appreciate all the opinions.
06-21-2008, 02:50 PM #32
- Mar 2008
- Central Maryland
- 246
06-21-2008, 02:55 PM #33
- Jun 2008
- Ontario, Canada
- 18
06-21-2008, 05:24 PM #34
Generally run a new line set when ever possible, but.
Got a fair amount of R410A swap outs that are using the old R22 line set.
Explain why they aren't causing any problems.
If your really worried about it, install the filter drier at the TXV where its suppose to be.
Not all manufacturers tell you to run new line sets.
06-21-2008, 05:29 PM #35
- Mar 2005
- Houston, Texas
- 11,644
My take on this is ,a contract is only good if it covers the home owner. We're only hearing 1/2 the story here. If the job isn't to your liking ,call them back. I won't call these guys hacks. I don't know the whole story,so I'll side with the contractor on this one.
06-21-2008, 05:59 PM #36
06-21-2008, 06:04 PM #37
06-21-2008, 06:05 PM #38
06-21-2008, 06:10 PM #39
When I blow out a line set with nitro, I blow it from the indoor unit to the outside with a rag around the line to catch any crap that comes out.
So there isn't going to be a bunch of crap in the lines.
Flowing nitro while brazing prevents oxidation, it doesn't create it.
I also flush from the inside when using RX11.
Still don't have these clogged TXVs you talked about.
