Results 1 to 6 of 6
    Chicagoland
    Furnace size VS. Man. J
    After calculating with man. J (on paper) a house shows 70400 (71* HTD). I am looking at goodman 90+ equipment. The 70 would undersize by 4000, the 90 would over by 14. Man. J says stay tight to results. Opinions?
    Lancaster PA
    Go with the 90.
    Nothing worse then finding out that the gas company is suppling gas with a 100 BTU lower content then you thought when its at design temp outside. That could put you at 10,000 BTUs light.
    Rochester, MN
    I'd go less. I did that on mine, and it keeps up just fine when it's -25˚ out.
    Lancaster PA
    Quote Originally Posted by mayguy View Post
    Shows that your calc was inaccurate.
    Not knowing how inaccurate his calc is, and in which direction, undersizing could mean he has a 10° cooler house at design.
    Apr 2008
    Alberta Canada
    it is based on output
    If the furnace is 70,000 x 90% = 63000 output and a 90,000 x 90% = 81,000.
    I would go with 90,000 just incase R-valve was high on something. Have a small safety factor.
    Do it right the first time.
    Jul 2005
    Quote Originally Posted by 21degrees View Post
    My thoughts exactly. Go with the larger one and get the benefit of shorter, but efficient, comfortable cycles, like my furnace with only about 2 six minute burner cycles an hour even at design temperature.
