Results 1 to 13 of 13
    Jun 2008
    Window Unit Oversize?
    Hey guys, my room mate is looking to buy a window unit for his room and he is asking why he shouldn't over size it. I told him that it will short cycle, which will not dehumidify, drop efficiency, and the unit won't last as long. He's wondering if he just drops the tstat to like 60 or something the unit won't pull down to wouldn't that work just as well? I'm not a 100% but I think the evap will freeze if there is no off cycle but I want to give him the correct answer. I'm still a student and still learning. Any help/feedback is much appreciated. Thanks
    Justin in Michigan
    Western NC
    buy one and put it in. They're cheap enough to break.
    Jun 2008
    Well I was really hoping to hear what would happen if he ran it all the time. 150 for the window unit is cheap but not for college students...
    Pretty safe bet that if it ever got to 60 degrees it would freeze over.....if it could only get it to 70 or so and not any further down then it might not.
    If you want to convince him not to oversize show him how much the weigh for each size
    Western NC
    window units are great to keep the air moving. Don't depend on it to cool the room to set temperature.
    I wouldn't recommend using it all the time either. Hook it up and only use it when your in the room to keep it from getting too stuffy and hot.
    Just like anything else, it can freeze up. As far as short cycling....gonna be hard unless you can find a 10 ton window unit. But if he doesn't know any better.....then make something up.
    North Carolina
    A little oversized on a window shaker won't hurt anything. Running all the time won't hurt it either. If he's in college and dumb enough to set the stat at 60 degrees and it freezes up - hmnn ???
    Why is it that 90% of people think an air conditioner will get cooler faster if they drop the thermostat way below the desired temp? The thermostat has nothing to do with capacity. It tells the unit when to start and stop and nothing else.
    An air conditioner won't freeze the coil because its running 24/7.
    The coil will freeze if its temp drops below waters freezing temp, weather it runs 5 minutes or 24/7.
