Results 1 to 13 of 27
Thread: micron gauge
    Jun 2006
    micron gauge
    I need to buy a new micron gauge Im thinking of the YJ 69075 or maybe the inficon pilot gauge. Any suggestions? I havent heard much about the inficon.
    i use and like the Y/J myself
    http://www.youtube.com/watch?v=nFl0n...ture=endscreen
    Apr 2008
    I also use the yellowjacket now.Just stay away from j/b went through two.Didnt last long.Total junk.
    omaha
    Question
    why not buy digital gauges with micron capabilities
    Apr 2008
    Very good point and working on it.Just very slow in the great state of michigan.
    Jun 2008
    Southern California
    Supco VG-64
    Anyone use the Supco VG-64. Just picked one up the other day, and its acting rather bizarre. After pulling a vacuum, I disconnect the hose from the system, and the hose is still connected to the micron gauge, with nothing connected to the other end of the hose, and the gauge would still read a vacuum. Just removing the hose wouldnt even get it to fall back to atmosphere reading, I would even have to remove the cap on the other side of the gauge, even though its just a Tee on the bottom of the gauge. I know this sounds really retarded, but I assure you I have tested this theory several times, and cannot figure out why it does it...
    I probably should just get it warrantied, but was curious if anyone else has used them.
    Jun 2006
    Ive never had any luck with supco. I dont know if it was the way I was using them but I had a couple of them fail rather quickly. I think Ill just go ahead and pick up the YJ 69075 then hopefully I wont have to pay for the same tool twice. That sucks
    Jul 2001
    VA
    Quote Originally Posted by johncavh View Post
    Because you need the micron gauge connected to or as close as possible to the system.
    Jan 2002
    Palatine Il.
    Quote Originally Posted by sysrq2000 View Post
    I have had the Supco VG64 for several years. I have found it almost critical to clean the sensor as described in the instructions using rubbing alcohol. I clean it every other time I use it, and any time it seems to act wierd. Also, it does seem to respond better when hooked up to the system, rather than at the manifold or the vacuum pump.
    several reasons like refrigerant oil ruins the sensor and saturating the sensor with liquid refer will ruin it. static electricity and there are more
    Dec 2003
    Citrus County, Florida
    I use the Yellow Jacket 69075. Have had no problems. Battery lasts a long time. 1 D cell.
    Doug
    Feb 2002
    Flemington, NJ
    Quote Originally Posted by Glenn Harrison View Post
    Ditto
    Jul 2000
    NW IL.
    In 89 bought a Thermal Care 4501 replaced sensors twice. Last year it got retired and replaced with the 14571. This one should last to retirement.
    Aircraft Mechanical Accessories Technician. The Air Force changed the job title to Air Craft Environmental Systems Technician. But I've decided I'll always be a Mech Acc.
